JCW Rookie wheel question for 17 inch wheels
Old Mar 7, 2020 | 02:56 PM
tweiss8's Avatar
tweiss8
Was looking at these wheels, and I noticed that the bore size was different.... would these clear the fat brakes on a 16 hardtop JCW? Maybe with centering rings? Maybe point me to a thread that has some other known Koenig wheels that can clear the brakes?
Old Mar 13, 2020 | 03:32 PM
rtowell's Avatar
rtowell
It's a pretty heavy wheel compared to some of the other options. The NM RSE05 only weights 17 pounds, which makes a noticeable difference in responsiveness. They are a bit more expensive, but not outrageous for a high quality wheel.
Old Mar 13, 2020 | 06:18 PM
tweiss8's Avatar
tweiss8
so.... is that a yes to the fit?
Old Mar 14, 2020 | 07:07 AM
robby71's Avatar
robby71
https://www.wheel-size.com/size/mini/cooper/2016/
As the F56 bore size is smaller you can but a spigot ring to reduce from the 73.1 to 66.6
https://www.ebay.co.uk/itm/73-1-66-6...8AAOSwImRYGzH5
Old Mar 14, 2020 | 03:42 PM
rtowell's Avatar
rtowell
You can probably make them fit, but you'd probably be better off with something that's specced for the car. Probably the biggest issue is whether the barrels will clear the brakes ... a lot do not. That's hard to tell without actually trring them.
Old Mar 14, 2020 | 03:57 PM
///Matthew's Avatar
///Matthew
Does TireRack sell these wheels? They will guarantee fitment if you shop by vehicle/trim.
Old Mar 14, 2020 | 05:05 PM
tweiss8's Avatar
tweiss8
thank you!
Old Mar 14, 2020 | 05:06 PM
tweiss8's Avatar
tweiss8
thats a good point as well!
Old Mar 14, 2020 | 05:08 PM
tweiss8's Avatar
tweiss8
I couldn't find them on tirerack, and discount tire direct doesn't seem to be able to add the JCW brakes as an option. They are cheap enough to buy one to try out.
Old Nov 13, 2023 | 07:44 AM
Cableaddict's Avatar
Cableaddict
I doubt these will fit. The only two 17x7.5 wheels currently guaranteed to clear the Brembos are Neuspeed RS +40 and Advan TC-4 +43. - And the latter only makes it because its spokes are extremely curved on the inside, which is something that raises the price significantly.
These wheels have pretty flat looking spokes and are +45. So .....
w00tMINI
Aug 14, 2019 07:14 AM
UNKORDT
R59 :: Roadster Talk (2012+)
12
Feb 19, 2012 07:00 PM
Soonersdude
Apr 18, 2008 07:58 PM
Drsms22
Tires, Wheels, & Brakes
Jun 14, 2007 08:12 AM
Morefun
Jan 17, 2005 01:33 PM
