R56 air filter box coming loose during rallycross
Old Mar 2, 2020 | 08:37 AM
kpierich's Avatar
kpierich
Running a 2007 R56 in rallycross and having an issue with the air filter box coming loose at the bottom grommets. Looking for way to hold the box in place. Thanks for any input.
Old Mar 4, 2020 | 05:10 AM
GsxR1000's Avatar
GsxR1000
FYI - On my U.S. 2009 MCS, while air filter housing/box sits in rubber grommets, it is held down by one captive-screw on paassnger side of air box. If my air box was disloging from grommets, first thing I would check is that one captive-screw is there and tight.
Good Luck...
Old Mar 4, 2020 | 06:17 AM
kpierich's Avatar
kpierich
Thanks for the suggestion, but after a couple events, not only will the grommet connections come loose, but the screwed connection splits too. You end up using zip ties and duct tape to keep parts of the car intact including the engine. I may have to manufacture some type of hold down clamp.
Old Mar 4, 2020 | 09:17 AM
Yep, and those grommets like to work there way out, see if one of them is cracked or popped out.
Old Mar 4, 2020 | 10:55 AM
kpierich's Avatar
kpierich
Thanks for the response, but due to all the bouncing around, all the grommets pop up. This system wasn't designed for this type of abuse. This issue won't be resolved by conventional means. Just curious if someone else runs rallycross and came up with a solution.
ti22fjc
Sep 12, 2013 03:00 PM
Chemdean
Jul 17, 2009 10:13 AM
NikiMae31
Jul 30, 2008 10:54 PM
davavd
Nov 20, 2007 09:34 AM
MINISPIDER
May 24, 2006 08:34 AM
