R50/53 P1498 code possible cause
Old Mar 1, 2020 | 11:34 AM
SupeR53's Avatar
SupeR53
Tigger threw me a P1498 a few days ago, since it was warm and sunny (finally) yesterday I had a chance to check him out. My scanner said that it was an unmetered air leak downstream from the compressor. Using the old carb cleaner trick of spraying around it the inlet tract, I found a hole in my intercooler on the passenger's side at the crimp I'm trying a temporary fix with JB weld to fill the hole. I'll keep folks posted as to whether it works or not. The Manual has no listing for the P1495 code, so I thought that I'd post what I found and my potential source for the code.
Old Mar 2, 2020 | 06:48 AM
MiniManAdam's Avatar
MiniManAdam
Community Builder
Is it a stock or aftermarket intercooler that has leaked ?
Old Mar 2, 2020 | 06:55 AM
SupeR53's Avatar
SupeR53
Stock Intercooler, the holes are right at the crimp along the short side. I started him last night to move him outside (so the DD for today would be warm and dry) and got no codes. I'll know more later this week. I'm wondering if its a stress issue since I replaced the intercooler boots last fall and I'm not sure that I got it located just right -it looks like its a bit to the passenger's side relative to the mounting points.
Old Mar 17, 2020 | 06:33 AM
SupeR53's Avatar
SupeR53
Solution works
So I finally got a chance to run Tigger today, no codes, no SES, no EML. The holes in the intercooler were the issue. JB weld, as much as I dislike using such things, has done the trick to reseal the seam. When I have time and $$ to do so, I'll put in a GRS motorsports intercooler.
I hope that this helps someone down the road.
mrcolby321@yahoo.com
Oct 12, 2019 02:52 PM
mitchh
Apr 1, 2014 11:27 AM
mona5255
Jan 29, 2014 08:04 AM
Tmini08
Jan 21, 2012 04:14 PM
