R56 Suggestions for additional proactive work when replacing the timing chain & tensioner
Old Feb 22, 2020 | 03:35 PM
Michael-Mini's Avatar
Michael-Mini
About 6 months ago, I purchased a 2008 R56 S with 48,000. It now has 55,000 miles and I am starting to budget to replace the timing chain and tensioner. Is there additional proactive work that makes sense to do at the same time as this work? Thank you in advance for advice.
Old Feb 22, 2020 | 03:39 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Front crank seal, alternator belt, friction wheel, valve cover gasket, replace PCV tube, double check that the water pump isn’t leaking...
Old Feb 22, 2020 | 03:44 PM
Michael-Mini
Thank you! The water pump was replaced about one month ago. I will add the other items to the list
Old Feb 22, 2020 | 07:54 PM
club_c's Avatar
club_c
I would also suggest the water pipe between the thermostat and water pump...
Old Feb 23, 2020 | 02:27 PM
oldbrokenwind's Avatar
oldbrokenwind
Valve grind / re-seat, and stem seals. Will improve performance and help with oil consumption / burning. Disadvantage is gotta strip everything off the head for a machine shop, unless you DIY, but even then you'll need a gasket set for all the "stuff" removed and re-installed. Also need a special tool to re-install FI seals, unless your local shop has one. Gasket kit will include all the above and herein mentioned head stuff EXCEPT the main head gasket, which is available in two thicknesses. Either one should be OK, even if the head is "shaved" to remove any warpage.
Philip J. Frye
Mar 11, 2020 05:42 AM
rondayvous
Feb 18, 2019 11:09 AM
rondayvous
Feb 14, 2019 04:53 AM
paultu1985
Apr 10, 2017 06:05 PM
bugeye1031
Nov 26, 2014 06:09 PM
