Headlight issue
Old Feb 11, 2020 | 07:56 PM
Calvin Petticrew's Avatar
Calvin Petticrew
Headlight issue
My passenger headlight went out I have replaced the bulb. Then thought it was the wiring inside since there were exposed copper wires so I replaced the whole assembly that didn't work check all fuses none blown, then replaced relay that didn't fix it. Could really use the help to fix this problem. If drive side light goes I am screw with no lights at all.
Old Feb 11, 2020 | 07:59 PM
Katgirl's Avatar
Katgirl
Well, that doesn’t make any sense, unless it is some weird coding thing. Maybe you have to electronically enter a new code. The only other thing that comes to mind is that it is the wrong bulb.
Kat
Old Feb 11, 2020 | 08:05 PM
Calvin Petticrew
Kat
The new assembly came with a bulb already installed. Also forgot to mention that the turn signal works fine.
minidd99's Avatar
minidd99
Do you have power to the headlight?
Old Feb 11, 2020 | 08:37 PM
Calvin Petticrew
The turn signal works so I would like so.
Old Feb 12, 2020 | 01:11 AM
giorgos's Avatar
giorgos
The turn signal has a separate wire.
Do you get a warning about the light not working? If not, there might be a broken wire somewhere shorting with ground (and dirt causing enough resistance for the car to think that the bulb is attached and everything is fine).
Also, check whether power does reach the wire harness (easiest with a multimeter, alternatively with thin wires and a bulb).
Where were the exposed copper wires you mentioned?
Old Feb 12, 2020 | 04:32 AM
Calvin Petticrew
They were old assembly between bulb and connector going out of assembly. But that is gone since I replaced the entire assembly.
Old Feb 12, 2020 | 05:44 AM
Calvin Petticrew
There is no warning lights on my dash.
Old Feb 12, 2020 | 05:56 AM
R55_'s Avatar
R55_
Hi - see https://www.northamericanmotoring.co...ght-issue.html - check the multiplug for crap/corrosion when you test
Old Feb 12, 2020 | 07:55 AM
adriancl's Avatar
adriancl
It often happens because of a defective bulb the FRM module locks the light on,without signaling light bulb burned on board.FRM module recoding is required, can be done with ICOM ISTA or with other diag tools.Here how it work with Launch X431.Video is for a BMW E serie, but is same procedure for Mini Cooper R56.
Old Feb 12, 2020 | 09:56 AM
Katgirl's Avatar
Katgirl
Good call! Defective bulb, though brand new. Now , that DOES make sense. Call whoever you bought the new assembly from, and ask them to send you just a new bulb, and you will send the first one back.
Kat
Old Feb 12, 2020 | 12:49 PM
Calvin Petticrew
If I replace the defective bulb do I still need to decide the FRM?
Old Feb 13, 2020 | 01:45 PM
Calvin Petticrew
Just check the connector to the assembly I doesn't get power. I tried the working headlight and I get power. So I think either connector problem or break in wire. Would the FRM effect both headlights if that was the problem?
Old Feb 13, 2020 | 02:50 PM
Calvin Petticrew
Just strip back some wire behind the connector and still no power so not the connector.
Old Feb 13, 2020 | 08:41 PM
adriancl's Avatar
adriancl
Headlight right and left have separate connection to FRM.So FRM can switch off only one headlight.
Minifan85
Jan 13, 2016 05:59 AM
morphix
R60/R61 Stock Problems/Issues
Nov 21, 2015 02:22 PM
DTIREY
R55 :: Clubman Talk (2008+)
Sep 29, 2015 01:00 PM
soccerbummer1104
Electrical
Jun 6, 2012 10:22 AM
heyjudes
Jun 13, 2011 06:19 AM
