R60 What parts to replace when installing a used engine
Old Feb 10, 2020 | 08:20 AM
Bnapton's Avatar
Bnapton
I recently acquired a 2013 Mini Cooper S Countryman with a bad engine (92K miles). I found a used working engine from a wrecked Mini with 62K miles. I currently have the old engine out and the used engine ready to go back in. It does not appear to have any oil or coolant leaks.
I'm looking for recommendations on what to replace and or look for before I install the engine eg. water pump, t-stat, hoses?
Old Feb 11, 2020 | 10:32 AM
Dwayne C's Avatar
Dwayne C
It would also be a good time to pull the intake and have a look at the valves.
Old Feb 11, 2020 | 10:51 AM
mikey_t's Avatar
mikey_t
I would probably do the timing chain guides & water pump while the engine is out of the car.
Old Feb 12, 2020 | 06:54 AM
+1 timing, valve cover, water pump, thermostat housing, water pipe.
Old Feb 12, 2020 | 07:04 AM
Bnapton's Avatar
Bnapton
The day I posted this, I had already placed an order for spark plugs a broken coolant pipe, filters, and spark plugs. The water pump and thermostat housing make sense as well, but did the newer N18 engines have issues with the timing chain and guides? I have a later 2013 build date.
The intake valves seem fine. I didn't see a lot of carbon build-up, but it would be nice to clean them up with something while it's still accessible.
Old Feb 12, 2020 | 12:53 PM
MiniToBe's Avatar
MiniToBe
take a look at the oil filter housing and turbo oil feed line. Although they may not be leaking, it might be a good preventative measure to replace them. Also, while the engine is out, if the car is Automatic, consider loosening the transmission fill plug for later service. with engine installed, it is harder to break that bolt loose.
carswithmuscles
Oct 20, 2014 06:20 PM
DCasey628
Jul 29, 2010 06:51 AM
turbo740
Jul 29, 2005 01:39 AM
