R56 Cylinder 4 misfire at idle only
Old Jan 30, 2020 | 06:43 AM
1silvermini's Avatar
1silvermini
I have a 2010 Cooper S with a cylinder 4 slight misfire on idle only. Misfire clears up with the slightest increase in RPM . I have swapped injectors, and coil packs...no change.
Old Jan 30, 2020 | 09:06 AM
MiniToBe's Avatar
MiniToBe
did you do a compression test? how many miles? timing chain ever replaced? carbon cleanup on the intake valves? did you also swap spark plugs, are they gapped properly?
Old Jan 30, 2020 | 10:17 AM
1silvermini
I did a compression test and they were all between 10% of each other ,the timing chain and guides,tensioner was recently replaced.i swapped the plugs and had the same results.checked the timing 3 times
Old Jan 30, 2020 | 10:31 AM
MiniToBe's Avatar
MiniToBe
any carbon build up on the intake valves? did you check for codes, even if there is no check engine light?
Old Jan 30, 2020 | 10:37 AM
Minidogger's Avatar
Minidogger
You can try cleaning the MAF too.
Old Jan 30, 2020 | 11:00 AM
1silvermini
It’s throwing a P0304 code for misfire as well as the check engine light. I soaked the valves in sea foam overnight but did not get them walnut blasted
Old Jun 15, 2022 | 09:06 AM
Ethompson's Avatar
Ethompson
Any update here? Similar symptoms, but have MAF code as well.
FrankBlack
R55 :: Clubman Talk (2008+)
Nov 5, 2019 10:22 AM
James Michael
Oct 17, 2019 11:49 AM
Eurotech1
14
Dec 29, 2016 08:08 PM
samtruongg
Aug 27, 2013 06:29 AM
Streakerr
Jul 16, 2013 08:51 AM
