R52 Steering Angle Sensor
Old Dec 23, 2019 | 10:50 AM
Laura Redd Casler's Avatar
Laura Redd Casler
Does a 2007 Mini Cooper S, R52, W11 have a Steering Angle Sensor? It has DSC but not ASC. Or, is it the other way around? Need to confirm. Thanks.
Old Dec 23, 2019 | 11:32 AM
Yes it does,
https://www.northamericanmotoring.co...le-sensor.html
https://www.ecstuning.com/Mini-2007-...ering/Sensors/
Old Dec 24, 2019 | 01:49 PM
OCR's Avatar
OCR
Mine died a while back too...and my 2005 just turned past 20,000 miles about two months ago..! WAY too soon for electronic parts to be failing.
I just turn off the DSC before I leave the driveway to make sure nothing interferes with anything else electronically.
The car's much more fun to drive with the "big brother" control turned off anyway.
Mike
Old Dec 24, 2019 | 07:10 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yes if you have DSC you will have a steering angle sensor.
If you are having steering angle issues before replacing it I would recommend recoding and aligning it first. That often can fix a fault with it.
But if that doesn't work replacing it isn't too bad, but will need to be coded after install.
https://www.waymotorworks.com/dsc-st...0-r52-r53.html
Old Dec 25, 2019 | 06:24 PM
OCR's Avatar
OCR
Thanks WMW.
But isn't the "coding" part the expensive...dealer operation only part ?
Mike
Old Dec 27, 2019 | 08:33 AM
WayMotorWorks
Vendor
Originally Posted by OCR
Thanks WMW.
Mike
I don't feel the coding is expensive. Most MINI/BMW shops can do it as it is a standard operation with the BMW software. So you need to see what your local place will charge to do it. Most good mechanics will agree to try and code it first, then only replace if it doesn't fix it.
Lex2008
Aug 15, 2015 01:49 PM
DTMR
Oct 14, 2014 02:05 PM
CSIBMINI
Apr 25, 2009 06:14 AM
Lost in Mini Land
Mar 22, 2007 06:52 PM
minifox2
Jun 2, 2006 10:40 AM
