R56 2008 R56 Right Mirror Moving While Driving
Old Nov 28, 2019 | 10:55 AM
doxley's Avatar
doxley
Recently, I noticed my passenger side mirror moving while I was driving. I thought there must be something loose. Checking it while stopped, the mirror seems solid, no play, no looseness.
Observing the behavior more closely, I noticed that it seems to respond to acceleration: it points up when I press the throttle. It also responds to braking, in that if I'm traveling down the road and the mirror is dancing around, I can step on the brake and the mirror moves significantly less or locks down and stops moving entirely.
Generally, It kind of looks like it's floating. Originally I thought the movement looked like random wind was being buffeted by wind.
The remote adjustment seems to work normally and I can see it influence the "base" position of the mirror even while it's moving on its own.
Thanks in advance for any thoughts or suggestions.
Old Nov 29, 2019 | 11:16 AM
Getn off's Avatar
Getn off
My wife just told me this was happening with hers last week. When I went to look at it, it fell off in my hand! A bit of gorilla glue later, and all is good.
Best take it off before the wind does!
Troy
Old Nov 29, 2019 | 02:30 PM
doxley's Avatar
doxley
Thanks, Troy. I had just figured out the same thing with mine and came to post that. It was hanging on just at the very top edge which made it hang tight/flat against the backing when observed statically. When I touched it, there was no movement. But when accelerating or driving at speed, it would swing out away from the backing. If only I had about 12" longer arms I could have figured it out while driving. :-)
Strange, simple, solved.
Old Dec 6, 2019 | 05:35 AM
MiniToBe's Avatar
MiniToBe
it happened to me at least three times so far (different minis) on of which, it fell on the street and broke lol.
mini-mine
May 22, 2014 11:51 AM
the matey
Mar 9, 2012 07:33 AM
JoeyC
MINI Camera and Video
May 18, 2011 06:31 PM
tubwreck
Jul 7, 2007 04:05 AM
Zarrik
Dec 30, 2006 05:18 PM
