R50/53 Squealing and rattling lost a little power
Old Nov 13, 2019 | 04:55 PM
theDonVon's Avatar
theDonVon
03 r53s started squealing last week a little then today it started doing it bad . Then heard a rattle I think I got it home just in time cause it started bogging a little twice for a second. Can a idler bearing make a squeal and I rattle sound? Any help please I need to get my mini healthy it's my only car.
Old Nov 14, 2019 | 07:08 AM
veedubpat's Avatar
veedubpat
Any of the pulley bearings on the serpentine belt side of the engine can scream bloody murder when properly failing.
Take the belt off and feel each by hand. If the tensioner and idler feel fine, check to see if the alternator is seized.
Old Nov 14, 2019 | 05:45 PM
theDonVon's Avatar
theDonVon
R53 squealing in chattering
I don't think it's the alternator because it still runs and turns I sprayed a little within grease on the pulley under the supercharger and it kinda went away any help I would appreciate it. Thanks
Old Nov 14, 2019 | 07:38 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
check the crank pulley as they are the most common failure causing belt issues. If it is wobbling or you smell burning rubber it is junk and time to upgrade to the ATI damper.
https://www.waymotorworks.com/super-...ulley-r53.html
Old Nov 22, 2019 | 11:50 AM
user 7389739's Avatar
user 7389739
>Squealing
>Rattle
>Bogging
As stated above check crankshaft pulley / dampener, mine went at 55K with 'normal' (no track) use. Reek of burning rubber and P1688 code thrown too. Thought I had a seized A/C compressor, hence the smell of a possible accessory belt melting while trying to turn it but it was actually the vulcanized rubber inside the dampener separating at failure. Bogging could be the car defaulting to limp home mode.
If you hear a rattle, could also be a timing chain / tensioner / guides issue, apparently very common on these Gen 1 cars. Search on "death rattle" and you'll find plenty on this subject to worry about.
MiniBlunt
Mar 20, 2018 05:04 PM
screwed36coupe
Oct 28, 2013 02:39 PM
Muguerza
Jun 8, 2013 04:37 AM
Enzof104
Mar 16, 2013 06:19 AM
conechaser05
Aug 23, 2005 01:18 PM
