R50/53 No power steering some mornings
My 2002 R53 77,xxx miles has no power steering some mornings.
At least, I think it's consistently mornings when it is an issue. I'll come back later in the day and the power steering is functional.
The power steering pump was replaced by MINI under recall in 3/2017, when I bought the car. There is no warranty beyond that one-time replacement according to my local dealer.
My local MINI mechanic, whom I trust, says the steering pumps working intermittently is not unusual.
Before I spend $1,000 replacing the pump, (or deciding to sell my MINI), does anybody have any thoughts?
Thanks!
Thanks!
Yep that alt, then check the connections on the power steering pump and alt/starter, they can get pretty bad or if you did work before come loose.
My PS pump went on/off/on a day before it died.
Then check places for leaks and not getting correct fluid flow.
https://www.northamericanmotoring.co...-2016-a-2.html
