engine issue
Old Oct 27, 2019 | 04:02 PM
Jason P's Avatar
Jason P
engine issue
Hello all. I am a newbie to Mini's. I recently bought a 03 mini base. I had an oxygen sensor fault and the guy I bought it from had new oxygen sensors. I installed both and cleared/reset adaptives. I drove it for about a month and started getting lean codes on bank one. changed fuel filter and reset some adaptives and have not had that code back but I am getting intermittant misfire cylinder 1. Tried new coils, plugs, wires, swapped injectors. sems to always run kind of rough at idle. Does the 2003 engine have the valve carbon issue? Does anyone have any other ideas? I can go weeks without a light on or sometimes it comes on within a day. Thank you
Old Oct 27, 2019 | 04:52 PM
ssoliman's Avatar
ssoliman
Lean condition could be vacuum leak. Try a smoke test. I have a link to a good smoker if you would like it let me know.
also could do a compression test and leak-down test
EMKFLYER
Jun 21, 2019 02:37 PM
EMKFLYER
Feb 6, 2018 09:50 AM
carcrafter22
Dec 24, 2016 12:30 PM
hotrods70
Apr 30, 2016 10:01 PM
VividLividity
Mar 3, 2013 05:39 PM
