R50/53 2006 mini cooper s parts compatibility
Old Oct 10, 2019 | 09:24 AM
Etceteraw's Avatar
Etceteraw
Good morning yall. I recently purchased a used 2006 mini cooper s with 90k miles on it for cheap, knowing it had some repairs that needed to be done on it. My mechanic quoted me for a few repairs:
New valve cover gasket
Rear wheel bearings
Lower control arm bushings
Ambient temp sensor + connector
And a transmission fluid flush and refresh.
First off, when looking up some parts(wheel bearings) i found some were only compatible with 2002-2005 models. Are there any other little things like this id have to look out for when looking up parts?
Does anyone have affordable parts suggestions for the repairs i need? Id greatly appreciate it.
Old Oct 10, 2019 | 09:47 AM
JAB 67's Avatar
JAB 67
RockAuto
Old Oct 10, 2019 | 10:19 AM
Etceteraw's Avatar
Etceteraw
Looks like the bearing hub comes in m14 and m12. Depending on what part of 2006 it was manufactured. Ie before or after 04/2006. Mine was manufactured on 04/26/06. Does this count as a late model??
Old Oct 10, 2019 | 10:39 AM
JAB 67's Avatar
JAB 67
The answer depends on the thread pitch of your lug bolts. You don't want to end up with one hub different from the other three.
Old Oct 11, 2019 | 07:05 AM
MINI33342's Avatar
MINI33342
Yes, late model fist gen.
Old Oct 11, 2019 | 04:45 PM
A383Wing's Avatar
A383Wing
if it's a late model '06 like mine, it will have the 14mm lug bolt threads in the hubs.....most every part store shows 12mm for the hubs....I just ordered a hub for my '06 R52 for a 2007 model car...fit perfectly
Bryan
Old Oct 11, 2019 | 05:09 PM
kensic's Avatar
kensic
i would buy the parts on FCPeuro because of their lifetime warranty.
gbfan10
Feb 14, 2018 08:33 AM
jesterjess
Aug 31, 2013 03:05 PM
jesterjess
Jul 10, 2013 06:43 PM
raveed
Feb 5, 2011 02:24 PM
PA2NY
New York/New England
Jun 27, 2008 05:47 AM
