F55/F56 Help : Rear License Plate Bracket
Old Sep 22, 2019 | 09:50 AM
Gchic's Avatar
Gchic
Recently just bought my 2014 MCS, and the bolts that would hold the license to the holder were stripped and rusted in so I just ended up buying a new license plate holder.
The part number that that was on the back of the original one was 51187160607 and that’s what I ordered through FCP Euro. When I went to pick up the package from FedEx I received part number 51139448724. Not sure if this part superseded the original one, but it doesn’t have a threaded insert to attach the plate to the holder on the top or bottom. FCP is closed today so thought I would ask the community. Did FCP send me the wrong item or does it just use self tapping screws now? Wanted to ask before I do something and it’s no longer returnable.
wat is alum
Old Sep 22, 2019 | 11:56 AM
sgscomps's Avatar
sgscomps
The bracket you received from the picture is a defective old style bracket that is missing the brass inserts.
BMW recently redesigned the bracket to use self tapping screws and eliminate the machine screws. The screw holes in the new bracket are smaller than the old screws.
When I would sell the old bracket I always gave people a little lubriplate to put on the screws to keep from locking up due to the dissimilar metal of the steel screw and brass insert.
Old Sep 22, 2019 | 12:34 PM
Gchic's Avatar
Gchic
Ok so I did receive the right one. You by chance know off the top of your head the size of self tapping screw I need? I’m guessing something like a M4?
Do you have a picture of the new style?
Old Sep 22, 2019 | 01:54 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Reread post#2, he says you got a defective product.
If it was me, I'd just epoxy nuts on the back of the frame and use it.
Old Sep 22, 2019 | 02:02 PM
tlhamon's Avatar
tlhamon
When I modified mine I had my dad fabricate some "nuts" for me by tapping a few pieces of steel bracket plate and then I Gorilla glued them to the back of the plate bracket. You can't see them anyway and they work like a charm. Also, didn't cost me anything since he had the parts lying around.
Old Sep 22, 2019 | 02:19 PM
Walt's Avatar
Walt
Very good advice!
After 10+ years, I can't unscrew the screws to get the plate off my R50.
Old Sep 23, 2019 | 12:46 PM
TVPostSound's Avatar
TVPostSound
The number is correct:
https://www.realoem.com/bmw/enUS/sho...diagId=41_2328
https://www.realoem.com/bmw/enUS/par...&q=51187160607
I have the same, and there are sheet metal screws for the plate
Sep 11, 2015 01:15 PM
banderlin
Oct 29, 2013 04:47 PM
sbpwjm
16
Nov 4, 2007 07:23 AM
2perCooper
Dec 12, 2003 01:22 PM
Needler
Feb 5, 2003 10:04 AM
