O2 sensor troubles
Old Sep 8, 2019 | 12:11 PM
Mlmini98's Avatar
Mlmini98
O2 sensor troubles
I own a 2005 mini cooper s that has had cel since I have owned it, every time I pull the code it says that the rear o2 sensor is reading lean. I just did a major service to the car, changed the supercharger oil ,added an overdriven crank pulley, changed the oil and coolant, and in this process I replaced the rear o2 sensor with a brand new one. I reset the code but it came back on and is the same one as before. Can someone please help me figure out what's going on with it? Note. it does not come back on while I am driving. I just reset and went for an almost 10 minute drive and took it almost all the way to redline and no code, but as soon as I got home and shut it off, I turned it back on just to see and instantly the code was back on.
Old Sep 13, 2019 | 08:24 AM
David Baker's Avatar
David Baker
Sounds like you may have an exhaust leak in your exhaust manifold between the two sensors. The stock manifolds are notorious for splitting a weld at the joint before the catalyst.
Old Sep 13, 2019 | 08:33 AM
Mlmini98's Avatar
Mlmini98
I will deffinatly check that out, thank you!
Old Sep 13, 2019 | 10:02 AM
David Baker
Here is a post you can reference for the possible leak.
https://www.northamericanmotoring.co...-manifold.html
Old Sep 19, 2019 | 07:39 AM
Mlmini98's Avatar
Mlmini98
So I looked into that thread you posted a link too and I was curious if you knew if deleating that pre-cat would cause a check engine light due to the downstream o2 sensor reading rich? P.S I live where there are no emissions.
Old Sep 19, 2019 | 10:10 AM
David Baker
Yes it will. You can put a O2 eliminator elbow on the rear bung and that usually fools the rear sensor enough for the computer to not throw a code.
alexs3d2
Sep 6, 2014 09:59 AM
tiny s
Jun 6, 2012 01:17 PM
Dano04
Feb 27, 2007 08:25 PM
Kendel72
Sep 1, 2006 07:57 AM
goin440
Jun 19, 2004 06:39 PM
