FS:: 2006 Mini Cooper S upper-engine rebuild OBO
Old Sep 5, 2019 | 07:16 PM
maxgilly's Avatar
maxgilly
2006 Mini Cooper S upper-engine rebuild and transmission OBO
Year: 2006
Model: Coupe
Price: $4750
Mileage: 162200
Color: Space Blue Metallic
Location (Region): Midwestern
Hello, new here ... and the first NAM post ever is a FS unfortunately lol
stock 2006 Mini Cooper S Gen 1 R53 hatchback (located in South Eastern Wisconsin)
6 speed manual
162,000 miles
New transmission at 65,000 miles
Brand new upper engine rebuild 150,000 miles
New clutch at 110,000 miles
Brand new brakes all 4 161,000 miles
New battery
Small cracked windshield
No working A/C, blows warm air (needs new condenser?)
Needs new exhaust (hole on one side)
Definitely needs a wax and buff
window tint 30% & 20% [07/30/2013]
Last oil change was [07/15/2019]
Aftermarket head unit and JL 12' subwoofer w/ JL amp (willing to take out sub and amp or leave in)
Comes with stock tail lights and stock radio as well.
Also have an unopened touch up paint: Item No.: 2BTL-BC Description: 2 oz Touchup Bottle, 2006 MiniCooper: Space Blue Metallic A49
Clean title
Any questions or for more photos, please ask. thanks
Engine Rebuild
  • Main Street Motors (Engine rebuild) [3/9/2018]
  • Car was over heated and will not start initial test showed low compression. Removed head, and found it to be warped from over heating. Belt has also broke and caused damage to valve train.
    • head bolt set
    • head gasket set
    • timing cover gasket
    • front guide rail
    • timing chain
    • timing tensioner
    • rear tensioner rail
    • oil filter
    • water pump
    • thermostat
    • air filter
    • serpentine belt
    • anti freeze
    • Mobile 1
    • rework cylinder head and deck
    • R&I cylinder head starter motor ($80 x 17)
    • remove and replace starter
    • starter motor
  • [11/6/2018]
    • Replace engine oil and engine oil filter. Check all fluid levels. Tire pressure
    • oil filter
    • battery and code to car
    • low power steering fluid CHF added
Other repairs
  • International Autos - MINI
      • [06/2018]
        • passenger headlight bulb
      • [05/30/2014]
        • new instrument cluster and computer
      • [11/27/2013] ($650)
        • front sway bar links
        • fix bad wiring for starter and power steering
        • serpentine belt
      • [08/23/2013]
        • battery
        • test A/C
new calipers, rotors, pads, and pins
new rotors, pads, and pins
doesn't really affect anything
willing to part with or take out
fairly clean interior when vacuumed
cracked windshield and not properly fitted side mirror
lots of paint chips on the hood
stock tail lights are included
Old Oct 3, 2019 | 07:34 PM
maxgilly's Avatar
maxgilly
blackmcs2005
Aug 29, 2019 12:34 PM
dhabutcher
Jul 15, 2019 12:10 PM
elan
Apr 28, 2019 06:06 AM
secondhandr55
R55 :: Clubman Talk (2008+)
Mar 9, 2019 06:29 AM
gum
Jul 21, 2018 03:37 PM
