2012 Countryman All4 rear passenger CV joint leaking?
Old Sep 5, 2019 | 11:51 AM
Dragonzsoul's Avatar
Dragonzsoul
Last weekend, I happened to look under the car for something that dropped, and spotted grease all over the passenger rear suspension components. I suspect it's the CV joint, but don't see any tears in the CV boot. Has anyone had similar issues on their All4 before? If so, are there any other symptoms I should watch for?
Thanks!
Old Sep 5, 2019 | 03:58 PM
2014 MC's Avatar
2014 MC
I don't have an all4 but mine is leaking at the driver side front outer. Upon cleaning the area up and close inspection, there is a small tear right where the larger side band clamp is, not the bellows.... Very small and hard to see but enough to fling probably most/all of the grease out and make a huge mess. Not sure what I want to do about it... Replace the boot or just leave it and see how long it lasts... I've seen some horror stories about getting that CV shaft out of the transmission due to ceased snap rings (dry with some rust) from the factory. Even about Mini techs having to replace transmissions due to stuck CV housing.
vixay
Feb 23, 2025 09:11 PM
goneFXcrazy
Feb 16, 2016 07:31 PM
chicohuahua
Apr 15, 2015 08:07 AM
UpstateCountryman
Jan 22, 2015 05:47 PM
