R50/53 Big service
Old Sep 2, 2019 | 10:41 AM
Island_Moose's Avatar
Island_Moose
Big service
Supercharger service and upgrade, new water pump,hoses, thermostat, plugs, timing cover gasket, harmonic pulley, tensioner mechanism, idler pulley, valve cover gasket.
Learn as I go. Have all the right tools.
Handy tool, use it all the time.
Might be original, bad shape.
Old Sep 2, 2019 | 11:14 AM
Island_Moose
Work is delayed while I source a tee-fitting for the cooling hoses that was brittle and snapped. Also my air compressor spat it’s tank valve so I’m fixing tools too 🙄
Old Sep 2, 2019 | 03:20 PM
jcolletteiii's Avatar
jcolletteiii
Great work man. I'm doing similar work on my 03. Original owner, but it has been sitting for a few years after it ran into head trouble. I'm doing it in a couple phases though - engine first. Head goes to be resurfaced this week, then the head gets a full rebuild. My thermostat looked just like yours. Will replace every gasket that I can get to for the head service, IC boots, plugs, filters. Then the fuel filter and once it's running I'll tackle the water pump, SC, and pulley. What pulley tool is that?
Old Sep 2, 2019 | 05:33 PM
cooper48's Avatar
cooper48
Nice work. Great way to learn about your MINI also.
Old Sep 2, 2019 | 06:43 PM
Snaps's Avatar
Snaps
If the Mini is never in front-end service mode, then you ain't driving it worth a damn!
But seriously, it is a good feeling when it is more learn as you go, then you realize you can do this, and when it's all finished, and it all works perfectly. It's a great feeling. Just wait until you change the clutch, and then you'll have learned something.
Old Sep 2, 2019 | 08:33 PM
Island_Moose
Cravenspeed makes the puller. I used a chain vice grip to keep it on the pulley as advised.
Old Sep 2, 2019 | 08:38 PM
Island_Moose
I was expecting some engine oil in the intercooler and intake manifold, and I certainly found a good amount. I cleaned the intercooler with kerosene and a soak in soapy water for 24hrs. It's pristine inside now, might cool marginally better as a result. The intake manifold is reasonably-easy to clean with brake cleaner on a rag wrapped around a stick. I didn't order an intake manifold gasket otherwise I'd have taken it off to clean.
In order to prevent getting oil mist back into the intake system I have purchased an oil catch can/breather system which will sit between the PCV valve and the grey tube that leads to the intake system.
Old Sep 3, 2019 | 08:27 PM
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
Originally Posted by Island_Moose
I was expecting some engine oil in the intercooler and intake manifold, and I certainly found a good amount. I cleaned the intercooler with kerosene and a soak in coasy water for 24hrs. It's pristine inside now, might cool marginally better as a result. The intake manifold is reasonably-easy to clean with brake cleaner on a rag wrapped around a stick. I didn't order an intake manifold gasket otherwise I'd have taken it off to clean.
Who ever wrote the description obviously never gone to business school. "Reasonably Construction" do not exactly inspire confidence. OK, I know. It is written by someone in China with a very elemental grasp of Kiwi English.
Good luck finding a place to mount the oil catch can. Despite the oil deposit in the IC I doubt there is any material difference without the oil coating. I bought a similar catch can and 2 years later still not convinced that I want to install it.
BTW, are you changing the bearings for the twin scrolls of the SC? If so can you share more photos and what you did?
Old Sep 3, 2019 | 09:32 PM
BlwnAway's Avatar
BlwnAway
If you've already bought this, be prepared to remove the filter, and cap the opening, that line needs to be a closed and sealed system, so be ready for that can to actually not have a decent (or any) one way valve for the filter.
Also buy a package of O-Ring's that fit around the dipstick to have on hand, I end up replacing one almost every time I check mine. And the dipstick doesn't seal well enough without one, or some thread sealing tape.
Old Sep 4, 2019 | 06:41 PM
Island_Moose
No to the bearings on the SC, it is not the original supercharger, and the oil in fact was just slightly discolored.
I'll let you know if I find a place to mount it.
Old Sep 4, 2019 | 06:42 PM
Island_Moose
Thanks for that. It arrived with the vent hole bolted shut and the filter as an option. I'll report back on the condition of the dipstick.
Old Sep 5, 2019 | 01:43 AM
Island_Moose
The dipstick is threaded, I’ll use tape.
Old Sep 7, 2019 | 08:19 PM
Island_Moose
Bracket fabricated and OCC installed. No interference, though it touches the hood liner.
Old Sep 19, 2019 | 01:16 AM
Island_Moose
New idler pulley, tensioner, seals etc etc etc.
Old Sep 19, 2019 | 07:23 AM
pnwR53S's Avatar
pnwR53S
Good job! You seem to have found the best location. I tried with my cheapo feaBay OCC almost identical to yours, and could not find a satisfactory location with routing of the hoses considered. The best location has to be the GTT and their, what appears to be smaller than usual, purpose made OCC for R53.
Did you install a Rivnut insert on the second hole that has no thread by the Cabrio brace?
Old Sep 19, 2019 | 02:55 PM
Island_Moose
Yes, I bought a rivnut tool when I installed the cabrio braces and it's my new favorite tool. I like your install location better, but my OCC unscrews from the bottom and I needed clearance.
Old Sep 21, 2019 | 11:18 PM
Island_Moose
My oil catch can system
Old Sep 21, 2019 | 11:19 PM
Island_Moose
Why I had no heat
From the heater core
Old Sep 21, 2019 | 11:22 PM
pnwR53S's Avatar
pnwR53S
Looks good, mate! I couldn't find my OCC. I eyeballed where you mounted yours and it seems awfully tight fit height wise. BTW, the GTT OCC and cabrio braces are mutually exclusive.
Old Sep 23, 2019 | 06:47 PM
Husky44's Avatar
Husky44
I like the design of this can and the location. Where is it from?
I know folks are skeptical on the need for an OCC. I'm not saying it's a "must-have" on an R53. I'm going on my experience with my last SC car, and of others with the same car. There was a night-and-day difference on the internals of the SC--cars without an OCC had a baked-on varnish; those running OCC stayed clean. I was surprised at how much condensate I collected with mine.
Thanks for posting the detailed pics
Old Sep 23, 2019 | 07:34 PM
Island_Moose
I removed 2-3 full tablespoons of engine oil from my intake manifold and intercooler.
Its basically an eBay special, less than $50
Old Sep 26, 2019 | 02:20 AM
Island_Moose
“Lifetime” filter
Old Sep 26, 2019 | 10:30 PM
Rah's Avatar
Rah
“Lifetime” filter
Got to love the lifetime claims sometimes lol. Good job on the process and the oil catch can. I am about to do the same on mine next week with a supercharger maintenance, so do you advise to do the OCC for sure? This is my first supercharged engine i usually always have turbo charged engines on my cars (VW/Audi background) If so can you guide me on where you purchased the OCC and did you piece it together or the kit came with the hoses and all? easy install outside of the bracket?
What did you use to clean the inter cooler, not sure i followed. Sorry for the multiple questions, just learning on this car!
Old Sep 30, 2019 | 01:10 PM
Island_Moose
The catch can istself was purchased on eBay, there are many like it but get the smallest one you can find. I think it's worthwhile, I cleaned a lot of engine oil out of my intake system.
The system is completly fabricated, I bought 3/8 and 1/2 vacuum tubing and lots of t-fittings and step-down fittings and clamps. I vent both sides of the cam cover to the OCC.
I cleaned the intercooler with CLR Grease and Oil remover (not the de-scaling stuff...they make 2 products), and kerosene. I soaked it in soapy water as well for a couple days.
Old Sep 30, 2019 | 07:48 PM
Rah's Avatar
Rah
Thank you for the answers, its going to happen this week so just want to make sure i am ready!
CXRK
27
Oct 22, 2019 04:40 AM
mdstandeford
May 23, 2019 08:54 AM
starionturbo
31
Feb 28, 2013 04:34 AM
Jeremy1026
R57 :: Cabrio Talk (2009+)
11
Aug 14, 2009 09:21 PM
