Outer ball joint removal - question
Old Aug 29, 2019 | 09:29 AM
JAB 67's Avatar
JAB 67
Beating on the control arm with a sledge hammer hasn't worked. Looking closely at the portion of the steering knuckle into which the outer ball joint fits looks to me as if the recess is open to the top. So, if I remove the axle can I beat on the ball joint from above?
Old Aug 29, 2019 | 10:09 AM
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
Even in the rust free PNW, I had to buy the cheapo HF separator. It is actually not too bad. You might have to load up the separator and still have to smash the control arm on the side.
You can beat the joint from above but you need to set up a solid support on the arm to do that.
Old Aug 29, 2019 | 06:12 PM
Racingguy04's Avatar
Racingguy04
That should work to get it out of the knuckle. I used, a chisel, flat bladed screwdriver, hammer, and some cursing. You might avoid pulling the axle if you use a long punch or screwdriver. I put some antiseize between the ball joint and the steering knuckle so hopefully it'll come apart easier next time.
Old Aug 30, 2019 | 03:24 AM
Petkorazzi's Avatar
Petkorazzi
What worked for me was to remove the knuckle entirely, put it in a vise, and use a long socket extension through the strut hole to bash the ball joint out from above. Yes, removing the knuckle takes time to do but it saves time in the long run compared to trying to chisel the joint out.
B dub
Nov 13, 2017 10:01 AM
RudeJoe
16
Jan 30, 2017 06:41 AM
YEZGUY
May 7, 2011 04:27 PM
JAB 67
Jan 23, 2009 10:49 AM
