Did you know we have a shift well cover for all three generations? We do!
It's the perfect compliment to our short shift kit and shift ****, though of course it will look fantastic with any shifter and **** combination.
We're big fans of the simple, mechanical look achieved by the shift well cover.
"What about the mode selector ring? Won't this eliminate that?"
Yes! This will remove the mode selector ring, but we've got a solution for that, too.
Using our OBD adapter with a smartphone running Bimmercode, you can change the mode of your MINI without the ring!
Or even have it start in your desired mode, for those who drive exclusively in one mode.
Of course if you have a switch rather then the ring, you're good to install the shift well cover with no worries of mode selecting.
