R50/53 What's this ?
Old Dec 7, 2004 | 09:18 AM
onasled's Avatar
onasled
What's this ?
OK, I'm replacing all rear control arms and came across this part. It's the box in the middle of the photo with the arm attached to the upper rear control arm, driver side. A quick call to Randy Webb and the answer was given.
Do YOU know what it is?
Old Dec 7, 2004 | 09:25 AM
mbabischkin's Avatar
mbabischkin
Either the transferse ODN power coupling to the flux capacitor, or the anti-matter particle injectors?
There's a reason I don't do that much work on my own car!
Old Dec 7, 2004 | 09:27 AM
MSFITOY's Avatar
MSFITOY
It's the pitch/yaw sensor for DSC I think...or the sensor to control the aiming of the headlamps
Old Dec 7, 2004 | 09:49 AM
mcowger's Avatar
mcowger
DSC sensor.
Old Dec 7, 2004 | 10:50 AM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
Headlight aiming sensor for the xenons on the right rear. If you dont have xenons, you dont have this part.
There is one on the left front as well. The system averages the readings between the two to determine the loading of the car and adjusts the headlight aiming accordingly. Actually a very sophisticated system for such a dinky car.
The DSC sensor is located behind the parking brake under the center console, ahead of the rear cupholder. Cars without DSC wont have this part.
Old Dec 7, 2004 | 11:04 AM
dominicminicoopers's Avatar
dominicminicoopers
See this thread. "My Rear End Squeeks"
https://www.northamericanmotoring.co...t=autoleveling
Old Dec 7, 2004 | 11:17 AM
MyPocketRocket's Avatar
MyPocketRocket
I think it's a flat tire monitor.
Old Dec 7, 2004 | 11:36 AM
MGCMAN's Avatar
MGCMAN
I ditto the cave dwelling Bear. He must know as its hibernation time and I suspect he's been reading up on his Bentley manual in that secret den of his.
Old Dec 7, 2004 | 12:00 PM
tontobird's Avatar
tontobird
I'm with Greatbear as I have no clue and he speaks with such authority and it makes sense!
Old Dec 7, 2004 | 12:33 PM
GRNSTRK2's Avatar
GRNSTRK2
DSC Sensor Specifics
So, does anyone have a link to more info on how the DSC sensor works? Just 'cause I'm curios, and have to much time on my hands to read...
Old Dec 7, 2004 | 03:17 PM
Paul!'s Avatar
Paul!
Infinite Improbability Drive.
-Paul!
Old Dec 7, 2004 | 04:07 PM
onasled's Avatar
onasled
'Greatbear' has it.
Now, to adapt it to the Alta control arm .... hmmmm...
Old Dec 7, 2004 | 04:43 PM
Ryephile's Avatar
Ryephile
Myth Buster Time: It's one of two attitude sensors for the Xenon headlights. The other is in the right front corner.
Old Dec 7, 2004 | 04:47 PM
mbabischkin
-Paul!
Would that be the Mark IV or MARK V model?
Old Dec 7, 2004 | 05:16 PM
Greatbear's Avatar
Greatbear
Methinks I'm being picked on.
I will now go back into hibernation and take my Bentley manual with me.
Old Dec 7, 2004 | 08:56 PM
lotsie's Avatar
lotsie
Don't hassle a bear while hibernating,or when they bother to make a statement,they will right.I know this about bears,I know very little about sensors
Old Dec 7, 2004 | 09:04 PM
4GAZM's Avatar
4GAZM
oh balive me its for the xenons !!!!!! my little arm brok off so when i play with it my xenons go up and down, its for when you have load on your car in the rear the lights ajust so its not blinding people coming in front of you!!!!:smile: :smile: :smile: :smile: :smile: :smile:
