Mini/MINI BUILDS Showcase your Build Talents.
Phantom Chili
Old Aug 28, 2019 | 11:28 AM
CCiPhantom's Avatar
CCiPhantom
Phantom Chili
Figured i'd start my cars thread here and get out of the 1st gear thread. Some information you may have seen in my introduction thread but if not, ill keep it chronological. Let's start with the name. The CCI Phantom VSC is my favorite paintball marker in which i played tournament with many years ago (long long time ago). Had it in anodized red, so Phantom Chili fits the bill. This is my first mini. Already one of my favorite vehicles ever and ive had them all from rice, to muscle, to euro, super sport bikes, supermotos, etc.
Current Specs:
11' MCS
6-Speed Manual
85k Miles
Chili Red - Checkered Slick Roof
2nd Cat & Res Delete
Air Diverter Valve mod with the BOV spacer thingy
Oil Pressure Gauge
Plans:
Wheels & tires.
Mild drop, maybe 1".
Upgrade the brakes.
Enclosure & sub for some bass.
Need a front license plate bracket & hardware. 4 holes in the front bumper now. Will a Euro front bracket use the same holes?
Needs a rear hatch button, have to use remote to open.
Need the driver side front lip thing.
Stay Tuned!
Old Aug 28, 2019 | 12:02 PM
CCiPhantom's Avatar
CCiPhantom
Wheels & Tires
Purchased a set of 16 x 6.5 SSP Type-C wheels (SSR Reps) from an R53 with Hoosier race tires.
Tires removed and wheels at the paint shop getting powder coated white.
Purchased and received a set of 205/50R16 Federal 595-SS tires the other days.
WMW M14 to M12 stud conversion kit is in with some wheel nuts & key i bought from amazon.
Looking at a gorilla lock set and more ring cameras for the losers that want to try and steel a set of replicas....
Replica BMW center caps in. Seen reviews of the logo peeling off so i think im going to clear coat them for some longevity, but for 7 bucks who cares.
Really don't know if i want TPMS... Little more than i want to spend but i dont want any dash lights on.
Old Aug 28, 2019 | 12:15 PM
CCiPhantom's Avatar
CCiPhantom
Dash light addressed.
PO has some LED parking lights installed which threw a code. Swapped them out for some amber ones. Compliments the turn signals and cleared the code
Going to do some headlight restoration here soon. So foggy!
Old Aug 29, 2019 | 06:13 AM
CCiPhantom's Avatar
CCiPhantom
Picked up my wheels from the paint shop yesterday and they came out perfect!
The BMW center caps didn't fit without modifications. There are tabs that dont "hook" in which i had to break off and file down. The 4 tabs with the lip hold the cap in place. 3 fit perfect, one it kind of loose (its the first one i tried to muscle on with all tabs, so 4 tabs with lips are bent slightly). Going to try and beef up the tabs with glue for now and order another set. All loaded in the truck ready for mount and balance!
Old Sep 1, 2019 | 12:40 AM
CCiPhantom's Avatar
CCiPhantom
Wheel studs in hand-tight to 8'lbs per WMW.
Wheel waxed & tires mounted (federals look awesome)
Little more poke than stock, thinking of 5mm spacers.
Torqued to 85'lb per WMW, running 100 miles then re-torque.
Drop to come later but sits ok, doesn't look too rally.
RF to Non-RF tires what a difference. So smooth, need to do a long commute to work and scrub them in.
Old Oct 6, 2024 | 05:15 AM
bobik89's Avatar
bobik89
Hello guys! Can anybody share please Flash and EEP for HW07 SW17? I cant find it on the net. Only one Ive found have 2mb lol instead 128kb. Im struggling to read it with r270 but I would say flash is already corrupted. When trying to write eep I get and error but al cables are quite short and soldered so I doubt the problem is in connection.
Thank you!!
Old Mar 9, 2026 | 09:09 AM
Jaymz81's Avatar
Jaymz81
Hi guys,
I have a 2006 Mini Cooper Park Lane, and I'm trying to retrofit the dual gauges (not the central console which sends the mileage data etc to the dual gauges over the steering column.
I'm stuck because I can't find a compatible (older) version of NCS Expert. I have V4.0.1, but I need 3.1.0 or 3.0.8 to talk properly with my car. Does anyone know where I can get 3.1.0?
BMW Tools Suite 2.1 contains NCS Expert 4.0.1 too, so no luck there.
I've been looking for days, so many dead links!
Thank you!
slimjimtell
Nov 9, 2018 05:32 PM
witecpa4u
R55 :: Clubman Talk (2008+)
Aug 25, 2013 08:15 PM
lil'valentino
MINI5280
12
Mar 21, 2013 09:59 PM
Arizonad54
Jun 13, 2009 12:43 AM
joltfreak
Classic Mini Talk
Mar 17, 2009 04:09 PM
