Mini Ready for AutoX this Sunday at COTA
Old Aug 17, 2019 | 02:19 PM
Darbys2019MiniJCW's Avatar
Darbys2019MiniJCW
245/45/17s on NM RSe05 17.7.5 Wheels...NM Exhaust...AWE S-Flo Intake and NM Power Module...Whole Engine Compartment where One Forge Hard Pipe can be seen...NM Black Front Strut Brace and K-Mac Camber/Caster Plates with Bilstein B14/16 PSS Adjustable Perches...Tires Clearance with 1.6 Front Degrees of Camber (1.7 degrees in rear).
Old Aug 18, 2019 | 12:32 PM
Darbys2019MiniJCW
So I finished in 2nd
1st Lexus IS-F V8 (416 Stock Horsepower) 40.809
2nd Mini JCW L4Turbo (228 Stock HP) 40.871 (.062 slower)
Was faster every run but one...out of 4 runs. I am thinking the taller 245/45/17's (even tho they are wider than the 225/45/17s) are too tall...25.7" vs 25". I know it isn't a binch...but I think
it is making a difference. I also had to raise the spring perches to fit the taller tires. I think I can fit the 245/40/17's up front which are only 24.7" and they will lower the Mini .5" without even adjusting the suspension.
They will also be wider by .4". I will use the taller 245/45/17's on the rear and the 245/40/17's on the front...OR...I just might run these until they are done and decide later.
I also still need to fine tune my driving some more so I should try it with these tires since I have been in 1st twice and 2nd once...gotta make myself a bit more precise...
Old Aug 18, 2019 | 08:53 PM
dube53's Avatar
dube53
Always interesting to read at your journey and "serious investment" about time and money in this project. You seems to have a big pile of tires and a lot of other bits to choose from depending of your daily mood LOL.
Old Aug 19, 2019 | 03:54 AM
Darbys2019MiniJCW
Actually ran the 225's and had someone who bought them off me while they still had some useful life left in them...now the 245/45/17's have not seemed to add performance with the Mini because of sidewall height and having to raise the suspension. I do think the 245/40/17s will be the ones that help all around. In the meantime, I will hone my driving on the 245/45/17s for the remainder of this season...maybe it is me and not the tires... ;-)
I do have the stock runflats and rims for everyday use … the ones you see in the pics
Marc08EX
Tires, Wheels, & Brakes
Jun 23, 2019 05:28 PM
Zackattack28
Sep 18, 2014 08:47 PM
Mark97xp
12
Apr 11, 2014 01:30 PM
watchinggoodman
18
Jan 10, 2013 09:18 AM
VanCooper
Jun 16, 2004 12:29 AM
