Outer ball joint stripped!
Old Aug 15, 2019 | 01:16 PM
Tybo88's Avatar
Tybo88
I recently put new wheel hubs on my R53 and was going to install a new ball joint buy when I went to screw the 2 13mm bolts into the knuckle they will not tighten up. What are my options other than buying a new knuckle!?
Old Aug 15, 2019 | 01:51 PM
A383Wing's Avatar
A383Wing
Options are:
Used knuckle, heli-coil, new knuckle, or maybe re-thread to the next size larger bolt size......
I assume that when you say the "2 13mm bolts", that you are referring to the socket size for the head of the bolt, not the actual bolt thread size, which I think is either 8mm or 10mm........
Bryan
Old Aug 15, 2019 | 02:16 PM
Tybo88's Avatar
Tybo88
Yes 13mn is the socket size I think the bolt is a M10 x1.0. I think I'll attempt the heli coil option first.
Old Aug 15, 2019 | 03:20 PM
Racingguy04's Avatar
Racingguy04
yup, I think helicoil is what I would do. If that goes wrong for some reason, here's another option. https://www.allmagautoparts.com/prod...21cd2174&_ss=r
Old Aug 15, 2019 | 03:33 PM
cooper48's Avatar
cooper48
I'm not sure I would want a helicoil on a critical suspension piece. Ball joints are not expensive. You can pick up a Bilstein on PartsGeek for $25.
Old Aug 15, 2019 | 03:46 PM
JAB 67's Avatar
JAB 67
The ball joint is not the issue; the bolts thread into the knuckle, and that is the part that would need replaced.
A383Wing's Avatar
A383Wing
The ball joint threads are in the knuckle, not the ball joint itself......the two bolts just go through the ball joint up into the knuckle, that's where the threads are
Bryan
Old Aug 15, 2019 | 05:23 PM
cooper48's Avatar
cooper48
A new control arm is $53 thru the same source. I've never used a helicoil so I'm not sure of their strength but for less than $100 you can replace the entire assembly and have some peace of mind.
Old Aug 15, 2019 | 05:29 PM
cooper48's Avatar
cooper48
Just realized that you're talking about the "carrier" when you say knuckle. Given that so many suspension pieces attach to this, including the hub/bearing, I would be very hesitant to jury-rig it with a helicoil. A used carrier might be your best option.
Old Aug 15, 2019 | 05:30 PM
A383Wing's Avatar
A383Wing
Again, it's not the ball joint or the lower control arm, it's the knuckle that the ball joint presses into.....the bolts are there just to keep the ball joint from popping down and back out....there is no real suspension load on the two ball joint bolts......a good heli-coil kit will be just fine
Bryan
Ronstang
Aug 28, 2018 06:05 PM
ijourneaux
Aug 20, 2018 06:52 PM
FallenBike
Tires, Wheels, & Brakes
Feb 26, 2016 05:22 AM
audio131
Oct 30, 2015 09:28 AM
crazyworld
Jan 15, 2014 05:38 PM
