R55 can't loosen Steering shaft pinch bolt?
Old Aug 14, 2019 | 11:47 AM
HBondar's Avatar
HBondar
Hi - I am in the middle of removing the tranny on my daughter'S 2013 Clubman(non-turbo) to replace the clutch. The subframe needs to be removed to do so. As a part of this process the pinch bolt on the steering column in the passenger footwell is supposed to be removed. It has a 13 mm hex bolt on one side and a small square captive nut on the other side. The captive nut looks to be be high strength (red) Loc-Tited. It spins when I turn the 13mm head. I tried vice grips but the loc-tite is so set that the vice grips don't work.
HAS ANYONE ELSE SOLVED THIS SEEMINGLY SIMPLE BOLT REMOVAL ISSUE.
thanks - H. Bondar
Old Aug 15, 2019 | 04:35 PM
MiniToBe's Avatar
MiniToBe
I removed it on three minis. no issues...try torching it and soaking it with oil penetrate.
Old Aug 18, 2019 | 06:14 PM
HBondar's Avatar
HBondar
Thanks - problem solved.
Old Aug 20, 2019 | 07:23 AM
Did you heat it up?
crazyworld
Jan 15, 2014 05:38 PM
Rx808
Mar 3, 2013 02:18 PM
Xio2018
Suspension
23
Mar 4, 2012 05:16 AM
pwarner
Suspension
Aug 23, 2009 03:38 PM
whyme26
Jun 21, 2009 04:00 PM
