sluggish around 2500 to 3000 rpms
Old Aug 12, 2019 | 07:16 PM
sohmbitch's Avatar
sohmbitch
really sluggish around 2500 rpms to 3000.sitting at light,idle seems to drop but never dies.step on gas sometimes and takes a few seconds for it to engage and pick up speed.changed coil pack,plugs,wires,bypass valve and fuel filter...still same problem....fuel pump?2003 mini s jcw..need help..
Old Aug 13, 2019 | 10:03 AM
ItsmeWayne's Avatar
ItsmeWayne
It may be the electronic pedal control under the gas peddle got wet/corroded, or going bad. There is a plug by the peddle that you can spray contact cleaner on, but if you have deffinate dead spots, it may need a new peddle sender.
Old Aug 13, 2019 | 10:36 AM
IQRaceworks's Avatar
IQRaceworks
Have you scanned the ECU in the car? Are you getting any codes?
pedalquickly
16
Aug 10, 2013 07:02 PM
soccerbummer1104
Jun 11, 2013 09:22 AM
simpsonna
Nov 4, 2010 10:22 AM
fly2xs
Oct 20, 2010 03:35 PM
jtack
Jun 3, 2008 04:54 PM
