R52 No High Speed Fan = bad resistor???
Old Aug 11, 2019 | 12:26 PM
Mini33073's Avatar
Mini33073
Wifes AC is not cooling efficiently and power steering fan doesn't turn on. I thought the PS fan was suppose to come on when AC turns on? Anyway I noticed the high speed fan doesn't come on at all. Pulled connector to radiator fan and tested 12v from battery to low speed and high speed pins. Low speed comes on, high speed does not. Could it be that the low speed fan resistor is bad? I replaced it like 3 or 4 years ago. If not this, what would prevent no high speed fan?
Old Aug 18, 2019 | 09:34 AM
ItsmeWayne's Avatar
ItsmeWayne
the high speed fan will not come on, until the engine starts getting hotter than it should. When you put on the AC, the low speed should come right on. if it does not, the low speed fan control, which is a common issue, needs replacing, but if neither come on, it could be a fuse.
JAB 67
Oct 24, 2024 03:43 PM
wickershaw
25
Apr 9, 2015 06:44 AM
Leema
Dec 15, 2012 11:17 PM
solus
Feb 14, 2012 06:16 PM
Richardotto
Apr 19, 2011 08:58 PM
