Wiring help?
Old Aug 8, 2019 | 11:56 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Wiring help?
I bought a cheap timer delay switch to control my sub woofer amp so that I get it to turn on after everything else turns on to eliminate the thumping sounds. It's a $3.25 investment (LOL) that I don't want to cause a bigger loss by incorrectly wiring it. So if someone has some solid knowledge on what wire goes where I'd appreciate the tips.
The green wire pictured - Control Switch, can't figure if that is supposed to be the control wire from the car audio coming in, or is that the wire going into my remote in on the sub amp? Depending on that answer I think it clears up the other side of the board where I assume I use the Normally open circuit to trigger the amp.
I'm confused.
Old Aug 9, 2019 | 08:21 AM
Walt's Avatar
Walt
I would guess that the green "control switch" wire is the power coming from your audio source (your radio or head unit). The blue-ish "load" "no" (Normally Open) wire is the power going to your sub amp. The blue-ish "com" wire is the raw power, and could be the same as the red +12v.
Old Aug 9, 2019 | 10:25 AM
Andy_S's Avatar
Andy_S
COM is usually common, or ground. It's more likely the corresponding return from the load.
Old Aug 9, 2019 | 10:49 AM
Walt's Avatar
Walt
Many times true, but not in this case. "COM" here seems to be referring to the relay, and "COM" is the common pad between either "NO" or "NC".
In this diagram, "1P" = "COM", "1T" = "NC" and "2T" = "NO"
Old Sep 26, 2019 | 08:51 PM
Minnie.the.Moocher
Never did get this switch to work. Eventually I decided to just wire a toggle switch to the remote amp wire and be done with it. Now I can shut the sub amp off as needed.
jaxmini
Electrical
Aug 22, 2007 08:24 AM
wheelspnr
Electrical
Feb 28, 2005 02:54 PM
efcmini
Oct 10, 2003 06:41 PM
Moorlockx
Electrical
11
Jul 10, 2003 06:32 PM
