Oil leak
Old Jul 30, 2019 | 09:42 PM
Scooter24's Avatar
Scooter24
Oil leak
Ok I have a oil leak at the rear driver side of the motor. When under the car i cam see it is running down on the power steering pump, starter and where the block and trans meet. It's not any further right (passenger side) from the starter it is just in that little area. It has a new valve cover and gasket. Any ideas? I'm going to try and look more into it tmrw. Could it be a gasket or somthing for the motor that runs the variable valve timing? The car is a 2011 mini cooper s.
Old Aug 2, 2019 | 01:36 AM
Scooter24's Avatar
Scooter24
this is where the leak is at, what is the round thing up and to the left of the starter?
Old Aug 2, 2019 | 06:40 AM
Turul YANIT's Avatar
Turul YANIT
It can be caused by possible oil leaks whick are vacuum pump sealing or oil filter housing sealing or cracks on valve cover or turbo oil feed line . So now check which one is leaking. Just observe it for 2 3 days
Was it s model ?
Old Aug 2, 2019 | 06:50 AM
Yupetc's Avatar
Yupetc
Color of that oil appears reddish. Doesn't look like engine oil. Check your tranny or diff fluid level. May be coming from the drive shaft seal failure.
Old Aug 2, 2019 | 06:57 AM
Turul YANIT
Agreed, might be
Old Aug 2, 2019 | 07:00 AM
Scooter24's Avatar
Scooter24
Was it s model ?
It's a 2011 MCS the photo is of the rear of the engine. It has a brand new valve cover and gasket
quikdime
Jul 5, 2019 10:17 PM
vhsnap
Sep 3, 2017 04:24 PM
DRoc7822
Feb 15, 2016 12:47 PM
MrCooperS
Dec 9, 2008 06:36 AM
22CooperS
Nov 27, 2007 08:12 PM
