R56 Water Pump Relaced New Problem
Old Jul 29, 2019 | 09:01 AM
Jrhuff's Avatar
Jrhuff
Hello, I'm brand new to the forum. My son has a 2011 Mini S with a turbo. I have never had a Mini before so not much experience with them. I changed the water pump this weekend by lowering and raising the motor. Everything went back together fine and refilled with coolant. Went to start it up and had smoke that smelled electrical fill the car and the car wont start. Had the battery checked and they say it is good. Any ideas?
Old Jul 29, 2019 | 09:46 AM
MiniToBe's Avatar
MiniToBe
welcome aboard friend.
was the battery connected when the work was performer? when you say the car wont start, does that mean it at least cranks? do you have an obd reader to check codes and/or if the ECU is responsive?
did you check the relays and fuses behind the passenger kick panel?
you may also find this sire useful newtis.info keep up posted.
Old Jul 29, 2019 | 09:54 AM
Jrhuff's Avatar
Jrhuff
Yes the battery was connected during the work process. It does not crank. I am trying to get my hands on an obd reader as we speak.
Old Jul 29, 2019 | 09:58 AM
MiniToBe's Avatar
MiniToBe
If it does not crank, that leads you to the starter. You could disconnect it and the battery and try to hot wire the starter.
Old Jul 29, 2019 | 10:09 AM
Jrhuff's Avatar
Jrhuff
Ok I've never done that but I can try to research how to do it.
Old Jul 29, 2019 | 10:31 AM
MiniToBe's Avatar
MiniToBe
sure...you can reach it from the bottom. there is on connector (signal wire) and one red wire (positive). disconnect the battery so not to back feed anything. remove those two wires. use a jumper cables or battery pack and connect the negative on the chassis. then use the red cable to touch the post between the starter and the solenoid. there will be some spark so safety glasses are recommended.
USNAE2
16
Jun 17, 2022 07:17 AM
cheetoman
Jun 7, 2019 08:55 AM
theimage
Feb 5, 2018 07:13 AM
BigGar
Apr 23, 2017 04:49 PM
Little Bean
R55 :: Clubman Talk (2008+)
Dec 26, 2012 03:23 AM
