Suspension refresh - need advice
Old Jul 25, 2019 | 07:05 PM
JAB 67's Avatar
JAB 67
2004 MCS, 160K. Original owner, never tracked or wrecked, recent replacement of all strut components, Powerflex on the LCA bushings about 50K ago. Still have some noisy looseness that I would like to eliminate, within reason. Thinking of front outer ball joints, and in the rear the sway bar bushings. However, can't decide whether to install Powerflex in the rear lower control arm bracket, or just install a new bracket. And, what about the lateral control arms? Do they wear out? Replace lowers only? Don't want to replace front inner ball joints and sway bar bushings until I decide whether to lower the subframe in order to replace the clutch. Your suggestions would be appreciated. TIA
Old Jul 27, 2019 | 08:20 PM
Aspen's Avatar
Aspen
Any rubber or ball joint is going to be pretty worn at that age and mileage. I would do all the front end ball joints and links. Do the front sway bar bushings too, maybe at clutch time.
Rear bushings will also be worn so new lateral links with bushings can't hurt, also RSB bushings.
Will you be keeping it forever? How is the rust situation?
Old Jul 28, 2019 | 04:54 AM
JAB 67's Avatar
JAB 67
No rust. Plan to keep indefinitely. Power train in very good shape. When you say 'lateral links' do the uppers wear out at the same rate as the lowers? Uppers seem much harder for a DIY change.
kroach01
32
Oct 29, 2018 08:45 PM
DamnCampers
Suspension
Feb 27, 2018 09:32 AM
Zsm
Suspension
Dec 4, 2017 01:47 PM
silence2-38554
45
May 23, 2015 08:11 AM
mikes603
Feb 15, 2015 08:25 AM
