FS:: Oem luk clutch kits 02-06 r53, 05-08 r52
Old Jul 25, 2019 | 02:17 PM
maxrevnhold's Avatar
maxrevnhold
Price: $75
Item Condition: Brand New
I HAVE 2 NEW OEM CLUTCH KITS FOR 02-06 R53 OR 05-08 R52
$75 EACH + SHIPPING
Old Aug 2, 2019 | 11:35 AM
LAMiniMe's Avatar
LAMiniMe
Is the LUK clutch kit complete to do a DYI clutch job for 2003 MCS R53?
Old Aug 8, 2019 | 06:38 PM
cyn18055351's Avatar
cyn18055351
Very Interested!!!
Hello I am very much intrested in this kit as I currently have a 2007 Mini convertible R52 that the clutch is about to completely go out can you please verified that this kit well work what that vehicle and that it is DIY..
If all works how soon can I get it??? As I stated above I dont have much time with the current.
Thx
Old Aug 10, 2019 | 04:57 AM
Cincy_jro's Avatar
Cincy_jro
Based on the listing it looks like a basic clutch kit which includes clutch disk, pressure plate, throw out bearing and alignment tool. It doesn't come with the flywheel which is recommended to replace since its a dual mass unit.
Mini clutches aren't an easy diy. You have to drop the subframe to gain full access to the transmission which means disconnecting the steering knuckle, power steering feed and return lines and all ball joints. If you are going to do it plan ahead and order replacement inner and outer ball joints and you may want to consider replacing / upgrading the lower control arm bushings and the sway bar bushings since you'll be in there.
Old Nov 29, 2019 | 08:26 PM
Black Forest's Avatar
Black Forest
Did you find a home for your clutch kits?
Old Mar 3, 2020 | 07:42 PM
A94cobra's Avatar
A94cobra
$75 not a bad price. Are LUK any good?
Ironoar
Mar 27, 2020 09:54 AM
LUSH 328
Dec 31, 2018 12:41 PM
Matthew Hardesty
Oct 19, 2015 07:01 PM
sujeemini
Jan 20, 2012 10:41 PM
