FS:: 2009 R56 S Premium Package w/ LSD, Manic Stage 3, Autocross Prepped 287WHP/307WTQ
Old Jul 18, 2019 | 07:50 AM
Dr. Spade's Avatar
Dr. Spade
Year: 2009
Model: Hardtop
Price: $4900
Mileage: 109400
Color: Laser Blue
Location (Region): SouthEast
Reason for sale: I have 4 cars. It's gotten out of hand
This is a fully loaded 2009 Cooper S, Laser Blue. Clean title. Purchased Certified Pre Owned (Vista Mini) with warranty.
Premium package with genuine leather, Xenons, Dual pane Sunroof, Blue interior accents, digital/auto climate, functioning Bluetooth, etc.
Receipts from Lauderdale Mini, Vista Mini and Motorworx for all work. Oil changes every 5K or less w/ Synthetic 5W-40.
New or recently replaced water pump, high pressure fuel pump, thermostat, timing chain, valve cover, JCW clutch & flywheel
Mods: M Factory Helical LSD (best mod)
Manic Stage 3 Tune by Lou w/ linear throttle
Alta 42MM turbo (Borg Warner)
Koni Yellow Shocks
Swift Spec R springs
Hotchkis 25.4MM Rear sway bar
Hotchkis rear camber arms
Ireland Engineering front camber plates
Hawk drilled/slotted rotors
Hawk HP+ brake pads
BMW DOT 4 brake fluid
Advanti Storm S1 17X8 +35 wheels
Federal 595 RSRR Tires 215/40-17 (45 profile closes wheel gap and also fits)
Made 287/307 on a Dynojet on 84 degree day with 93 Oct pump gas
Exterior and Interior both 9 out of 10. There is one single minor ding on passenger door and some minor rock chips in front.
Located in Ft. Lauderdale, FL. Car is driven once a week, miles will increase slowly.
Old Jul 18, 2019 | 06:18 PM
mountainhorse's Avatar
mountainhorse
Nice looking MINI !
Friend is looking in T/SP area.... I'll send on your info.
Has the valve carbon service been done (walnut shell blasting)?
Old Jul 19, 2019 | 06:04 AM
Dr. Spade's Avatar
Dr. Spade
Originally Posted by mountainhorse
Nice looking MINI !
Yes it's done the proper walnut shell blasting at dealer once, then a basic carbon cleaning recently. No CELs, issues, etc.
Old Jul 28, 2019 | 05:50 PM
Dr. Spade's Avatar
Dr. Spade
Up
Old Aug 5, 2019 | 03:48 PM
Dr. Spade's Avatar
Dr. Spade
Bump
Old Aug 7, 2019 | 08:25 AM
Dr. Spade's Avatar
Dr. Spade
Up
Old Aug 28, 2019 | 08:48 AM
Dr. Spade's Avatar
Dr. Spade
Price dropped to $8,900!
Old Nov 28, 2019 | 09:30 AM
Dr. Spade's Avatar
Dr. Spade
Lowered price to $7,900!
Old Dec 18, 2019 | 07:20 AM
Dr. Spade's Avatar
Dr. Spade
Still for sale. But at this point I'll probably use it for MOTD
Old Dec 20, 2019 | 07:31 PM
Dr. Spade's Avatar
Dr. Spade
Pending sale
Old Dec 23, 2019 | 08:30 PM
Dr. Spade's Avatar
Dr. Spade
Buyer MCS02 backed out last minute after I was kind/stupid enough to drive with two cars up to Knoxville, TN from Ft. Lauderdale, FL.
It is still for sale and I'm near Knoxville...
Old Dec 24, 2019 | 01:54 PM
Craig Moore's Avatar
Craig Moore
A bit interested if you can confirm it isn't a" track rat" based on your past posts of fun at Sebring !! Was the clutch pre or post track day(s) ? Any undercarriage/splash shield damage from Offs? I'm near Asheville, NC not too far from Knoxville if you're still in the neighborhood.
Old Dec 25, 2019 | 09:03 AM
Dr. Spade's Avatar
Dr. Spade
Definitely not a track rat, and no offs. It's a track-able daily. More of a Tail of the Dragon rat than anything. I haven't done a track day with it (only autocross) since clutch/LSD.
Call me at 954-790-2408. Merry Christmas
Old Dec 25, 2019 | 05:42 PM
ItsmeWayne's Avatar
ItsmeWayne
Koni Yellow Shocks
Hawk HP+ brake pads
It is a great looking Mini. I had one very similar to that. I sold it to a guy and ended up have to work on it a few months trying to get it smogged. Even with a new cat!
I was almost ready to buy it back! Intake air leaks, bad cam vanos relays!
Old Dec 26, 2019 | 06:44 AM
Dr. Spade's Avatar
Dr. Spade
Thanks man.
I actually smoke tested it for leaks and found that there was a small leak in my oil catch can! So that got fixed.
Vanos relays were replaced a separate time as well.
As for my cat, I know it won't pass California, but should pass the rest. I guess being in Southeast has its perks.
Old Jan 17, 2020 | 07:10 AM
Dr. Spade's Avatar
Dr. Spade
UPDATE - Mini needs an oil filter housing.
I need to pay back school tuition for completing MBA
Price dropped to $4,900 given it will need to be towed away.
Old Jan 17, 2020 | 07:36 AM
Craig Moore
Sorry to hear that...is there an internal coolant/oil admixture or only an external leak ?
Old Jan 17, 2020 | 08:08 AM
Dr. Spade's Avatar
Dr. Spade
External, but definitely both.
Old May 6, 2020 | 06:02 PM
zrickety's Avatar
zrickety
SOLD! 5/3/2020
Has no MAF, with TPMS and CEL lights on. Exhaust isn't quite right and the tires are toast but you gave me a good deal.
P.S. Car was clearly overheated, melted valve cover underneath, one of the valve seats falling out, machine shop has the head. I've spent almost $3000 on parts, that does not include labor...car is still not back together yet. 6/17/2020
Edit- for the record, I got the car all together last fall, having spent even more money. It ran well for about 20 minutes. All new cooling system parts and it still uses coolant and overheats. I'm parting it out now.
This car was a basket case. 2/20/2021
Bnourai
Jun 26, 2019 10:39 AM
nels415
Jan 13, 2019 06:28 AM
jetsr6
SCCA Solo and ProSolo
Nov 23, 2018 09:35 AM
co0p3r
Jan 31, 2017 03:20 PM
