Oxygen Sensor problem
Old Jun 20, 2019 | 01:13 PM
MiniClubbie's Avatar
MiniClubbie
Dear All,
My Mini threw CEL this morning. I checked it with ISTA+ and there are two faults:
1. Too lean mixture (002BC0)
2. Oxygen sensor after catalytic convereter, too high internal resistance
I did some testing and faults appear once engine gets warm. First appears the fire st fault, than after longer driving - the second one. I have checked the oxygen sensor after converter with multimeter and it shows 6.6 ohms. Is this correct value? Or should the sensor be replaced? Shall i be looking for other symptoms or perform any further diagnostics? The car has 60k miles on it.
Old Apr 7, 2020 | 07:54 PM
BNP's Avatar
BNP
Did you ever happen to resolve these issues? I've been getting the same codes in ISTA and tried replacing the rear O2 sensor with an OEM one. Still get the same codes with the addition of P0136.
Scott Delaney
R55 :: Clubman Talk (2008+)
Dec 21, 2016 10:08 PM
Sabini
Oct 30, 2013 11:10 AM
Jesperss
Jan 24, 2013 10:43 PM
Jesperss
Oct 30, 2012 07:41 PM
Intrnlstorm
Jan 18, 2012 10:39 AM
