FS:: 2004 Mini Cooper S
Old Jun 18, 2019 | 12:26 PM
bron's Avatar
bron
2004 Mini Cooper S
Year: 2004
Model: Coupe
Price: $2400
Mileage: 100700
Color: Silver
Location (Region): NorthWest
I have a 2004 Mini Cooper S with a manual transmission. It is priced low because I believe it needs a supercharger(still runs just noisy) and it also has a rebuilt title(no frame damage). I have replaced a lot of parts on this car, but I'm over Mini's and will be getting another car. The crank pulley will also need to be replaced(I have the gasket and bolt and can buy the Alta pulley if wanted) Exterior is not so great 5/10, interior is a 8/10. Also have a used exhaust and megan racing header that I can give.The car is located in Portland,OR.
Modifications within the last 10k miles:
Bytetronik Full Access with Data Viewer
Alta 15% percent supercharger pulley
Detroit tuned bypass valve
Lowering Springs with adjustable control-arms
Window Tint
Maintenance within the last 10k miles:
Front/rear Bilstein Shocks
Federal ss595 tires all 4
Clutch replaced
New brakes/ rotors
Battery
Oil Cooler Gaskets
Oil pan gasket
Valve cover gasket
Crankshaft o ring
Air intake filter
Front and rear sway bar bushings
Power flex control arm bushings
Outer ball joints
New spark plugs/ coil wires
Strut towers
LD pump
Windshield wipers
Intake air duct
Vacuum lines
Coolant, brake fluid flush
Idler pulley
Belt tensioner/ Belt
Front Motor Mount
Lower engine Motor Mount
Outer/ inner tie rods
Drivers side axle
Wheel Bearings
Fuel Filter
Transmission Fluid
Royal Purple Oil change every 3k miles
Old Jun 18, 2019 | 12:28 PM
Marc08EX's Avatar
Marc08EX
Damn that car looks good for the price.
Old Jun 18, 2019 | 03:49 PM
gumbedamit's Avatar
gumbedamit
Great Looking car, is there anything wrong with it?
Old Jun 20, 2019 | 10:52 PM
bron's Avatar
bron
Sold.
tonyferrari
MINIs and Minis for Sale (archive)
May 7, 2008 02:52 PM
Rick-Anderson
Oct 4, 2007 07:07 PM
Lost240
Aug 20, 2007 08:51 AM
mr. jim
Jun 6, 2007 07:03 AM
