2004 Mini Cooper S
I have a 2004 Mini Cooper S with a manual transmission. It is priced low because I believe it needs a supercharger(still runs just noisy) and it also has a rebuilt title(no frame damage). I have replaced a lot of parts on this car, but I'm over Mini's and will be getting another car. The crank pulley will also need to be replaced(I have the gasket and bolt and can buy the Alta pulley if wanted) Exterior is not so great 5/10, interior is a 8/10. Also have a used exhaust and megan racing header that I can give.The car is located in Portland,OR.
Modifications within the last 10k miles: Bytetronik Full Access with Data Viewer Alta 15% percent supercharger pulley Detroit tuned bypass valve Lowering Springs with adjustable control-arms Window Tint Maintenance within the last 10k miles: Front/rear Bilstein Shocks Federal ss595 tires all 4 Clutch replaced New brakes/ rotors Battery Oil Cooler Gaskets Oil pan gasket Valve cover gasket Crankshaft o ring Air intake filter Front and rear sway bar bushings Power flex control arm bushings Outer ball joints New spark plugs/ coil wires Strut towers LD pump Windshield wipers Intake air duct Vacuum lines Coolant, brake fluid flush Idler pulley Belt tensioner/ Belt Front Motor Mount Lower engine Motor Mount Outer/ inner tie rods Drivers side axle Wheel Bearings Fuel Filter Transmission Fluid Royal Purple Oil change every 3k miles https://cimg3.ibsrv.net/gimg/www.nor...63336e81d0.jpg https://cimg1.ibsrv.net/gimg/www.nor...1d22a18578.jpg https://cimg2.ibsrv.net/gimg/www.nor...39aeb24aa5.jpg https://cimg7.ibsrv.net/gimg/www.nor...fb724c91c6.jpg https://cimg8.ibsrv.net/gimg/www.nor...d28977a210.jpg https://cimg9.ibsrv.net/gimg/www.nor...279fb6777d.jpg https://cimg0.ibsrv.net/gimg/www.nor...5b3d8d126c.jpg https://cimg1.ibsrv.net/gimg/www.nor...d3352233d1.jpg https://cimg7.ibsrv.net/gimg/www.nor...ac4a0f3c88.jpg https://cimg8.ibsrv.net/gimg/www.nor...407814a784.jpg https://cimg0.ibsrv.net/gimg/www.nor...af8ca665b9.jpg https://cimg1.ibsrv.net/gimg/www.nor...44d2c92e77.jpg https://cimg2.ibsrv.net/gimg/www.nor...8f91cae7ad.jpg https://cimg3.ibsrv.net/gimg/www.nor...c35280fbf4.jpg https://cimg0.ibsrv.net/gimg/www.nor...94058c9826.jpg https://cimg4.ibsrv.net/gimg/www.nor...a15069151d.jpg |
Damn that car looks good for the price.
Great Looking car, is there anything wrong with it?
Sold.
