2nd Gen Countryman (F60) Talk (2016-2024) Second Generation Countryman discussion. F60
F60 Roof rack instructions
Old Jun 14, 2019 | 09:20 AM
maxou723's Avatar
maxou723
Hi, just wondering if anyone has a pdf or a picture of the instructions for the Mini Countryman roof rack. I bought them used from someone and he didn't have the instructions anymore. (part 82712327922)
Thanks for your help if someone has it!
Old Jun 14, 2019 | 10:09 AM
Blu_lite's Avatar
Blu_lite
Remove covers with the key.
Loosen the clamps by turning the plastic nut behind the cover.
Place clamps on roof rails.
Tighten the clamps.
Replace covers.
If you are putting on a heavy load, I would suggest that you tighten the clamps again after it has been loaded. I find that with heavy weight 50lbs+ it puts enough pressure on the clamps to slightly loosen them. Therefore, i tighten them again.
Old Jun 14, 2019 | 10:13 AM
maxou723's Avatar
maxou723
Thanks, is there a recommended or minimum distance between the front and rear bar according to Mini?
Old Jun 14, 2019 | 11:43 AM
d2mini's Avatar
d2mini
I don't have a CM yet, but on my Audi (I would expect MINI to be similar) there were two little holes on the inside side of the rails that matched up with two pegs on each foot of the rack.
Take a look. There has to be something. Rack crossbars can't just go on ***** nilly.
Old Jun 16, 2019 | 02:04 PM
ND40oz's Avatar
ND40oz
Audi is a bit different, besides using the holes to know where to place the bars, they also use the holes to change the stability control program. One of the rails on my SQ5 had 3 holes for an electrical signal to tell the car the roof rack was on.
BMW usually lists the measurements down to the mm of where the rails should be mounted in the install instructions. They'll include stickers that you can place at the top of the door jam so you know where to mount the rails each time. At least that's how it worked on my F31.
Old Jun 20, 2019 | 12:07 PM
Stretch-22's Avatar
Stretch-22
The locations for the front and the rear mounting points are marked on the vehicle.
For the front location, it is marked with a small triangle. Stand near the driver's side door and look across at the other roof rail. As the curved surface of the silver roof rail comes up and starts to become flat, look down at the black support on the underside of the silver part. There is a small triangle indentation of the black part. Center your front bracket on that triangle. It is on both sides, but since it is inboard on the roof rail its easier to see when looking across at it.
For the rear location, it is marked with a small circle on the underside of the roof rail. It is located about 8 - 10 inches in front of the rear black support. If you lean down you can see it or just run your finger along the underside to locate it.
Old Jun 27, 2019 | 08:47 PM
jvanbrecht's Avatar
jvanbrecht
Aren't the OEM rails made by Yakima.. The instructions are probably the same.. just hit up Yakimas web site.. Or Thule.. it is one of those 2.
Old Mar 20, 2021 | 03:39 PM
darex's Avatar
darex
I see the markings you're referring to, but I'm having turmoil about the front one. The black plastic mount is flush with the rail at that point. Most crossbar clamps have to "clamp" but that's not possible at the location of the triangle. All the recommended clamps for F60 Countrymans seem to be of the clamping around kind; whereas, it seems clear that the type required would clamp into the rail's grooves, like a flush-mounted BMW rail would require, not around the rail entirely (e.g. Thule's fitment guide says the Thule 710400 Evo Raised Rail foot is the correct one). This is further conflicting with Thule's recomendation for a 28" bar spacing, but the F60's spacing between the two markings is only 26".
Why is this so complicated!?
Old Mar 21, 2021 | 04:58 AM
Mini-Titan's Avatar
Mini-Titan
The gray part is what is tightened by the ****, and the gray part is what fits into the groove of the rail. The black cover is just that, a cover...it doesn't serve to hold the foot to the rail.
It doesn't matter if you read somewhere that it's 28 inches, but, you find it's 26 inches. It's immaterial to it's function, unless you are going to stress the system to it's absolute maximum limit. Even then, there is some leeway on exact spacing.
I will also mention, with the risk of increasing the complication level, that the black tightening **** will interfere with the black cover unless you turn the **** so that it forms a "Y" when viewed while standing facing the car....as in the illustration above. Otherwise, the black cover won't close easily. This is illustrated on a diagram inside that foot.
Old Mar 22, 2021 | 06:00 PM
Stretch-22's Avatar
Stretch-22
I have only owned the rails and box from Mini, but here are my thoughts. The mounting points and spacing that Mini specifies are likely based on the weight distribution that they designed into the rails. So aftermarket specs may be close, but slightly different because they are designed for a variety of vehicles. It's probably ok if you are close and the total weight limit is not exceeded.
lsirois
May 30, 2023 12:37 AM
CrewChief
R55 :: Clubman Talk (2008+)
Oct 4, 2013 02:22 PM
Mark Quarum
Oct 27, 2009 01:45 PM
dinandriver
Aug 10, 2006 08:26 AM
BriNYU
17
Dec 15, 2004 08:25 PM
