Chemical smell / possible evaporator leak
Calling all car experts out there! A strong chemical smell started blowing in through the vents shortly after getting the micro filter replaced at the dealership. Now they’re telling me there’s a leak in the evaporator and it’s leaking freon - which is crazy $$$. (Just a strange coincidence?). And does Freon have a smell?
Note: The A/C blows very cold, albeit with that awful smell. I also smell it when the heater is on, or just the vents running.
Anyone familiar with this kind of situation? Any advice? I have a 2012 Hardtop.
Also: There is NOT any kind of gas leak.
Thanks!
Thanks!
Thanks!
Thanks!
On your driveway not much you can do unless you can spot an oil stain on say the evaporator. Not sure how accessible this is and how much of it you can see.
If you want expose the cabin air filter and make sure it is installed correctly. Shine a light down into the air passage under the filter and see if you can see anything down there, any signs of oil or even an accumulation of water.
Which reminds me: Any chance the shop sprayed some cleaner or something that is supposed to remove any possible mold/mildew that can sometimes accumulate on the evaporator?
If you can't spot anything you'll have to have this looked into of course and before I signed off on a new evaporator I'd want a high confidence diagnosis that it was the evaporator leaking. That is I'm not a fan of funding a shop throwing parts at some odor, or other symptom. The service department should be able to clearly ID the leak and make sure it is on the only leak before it throws parts at the smell.
coolant has a strong smell especially when it hits the exhaust and cooks off
when I've had a refrigerant leak I never knew it til the a/c failed ... never smelled anything
but as mentioned just about any decent garage can check the a/c pressures and tell if you are down .....
dami
May 19, 2023 02:03 AM
