R58 How does the smart alternator system work?
Old Jun 1, 2019 | 01:59 PM
gchin's Avatar
gchin
I had a problem with the battery warning light coming on after not driving for about a week.
I drove the car to a shop to check the battery and charging system, and they both passed the test. Then I read about the smart alternator in some cars are designed to keep the AGM battery around 80% charged. I was usually doing short drives mostly during the day, then leaving the car in our garage for about a week.
After reading that the smart alternator may change its charging voltage depending on the electrical load, I am trying to do all my short drives with the headlights on.
So far I have not had the battery warning light come on any more.
Does the R58 have a smart alternator?
Old Jun 4, 2019 | 01:16 PM
If you have the IBS system (smart battery system) you will have this: 12427603567
https://www.ecstuning.com/b-genuine-...427603567~oem/
Old Oct 26, 2019 | 03:24 PM
Mini mikelee's Avatar
Mini mikelee
I have the IBS system with that current sensor. My car was originally fitted with a Gel Glass Mat battery but when I bought it it was fitted with a normal lead acid battery. I have a Carly adapter and after fitting you are meant to reset the system for the battery capacity and type. This apparently optimises the charge and minimises the alternator load
jacobarber
May 3, 2019 09:55 PM
scottwitha5
Mar 23, 2019 04:26 PM
jimatvs
Jun 23, 2009 09:52 AM
owl
Apr 8, 2009 05:06 PM
ssteve
May 3, 2007 08:16 PM
