R56s (2012) - Transmission 6th gear
Old May 21, 2019 | 02:09 PM
packman86's Avatar
packman86
I have an R56s N18 manual transmission (78000 miles) that is having an issue with 6th gear.
The shifter tries to pop out of 6th gear when I accelerate. It also seems to jump out of 6th randomly when I drive on the highway.
I can see the gear **** creep towards neutral when I accelerate in 6th gear.
Anyone know if there is a quick/cheap way to fix this?
Old May 21, 2019 | 05:04 PM
MiniToBe's Avatar
MiniToBe
Check the coolant pipes under the hood. They might be in the way preventing a full engagement.
Old Aug 9, 2019 | 11:26 AM
miniuy's Avatar
miniuy
Do you have an update for this packman86?
I'm in the same boat and the problem is a bad driving habit (running on low revs with 6th gear engaged).
In my case the 6th gear and the synchro (5th - 6th) are worn
Old Aug 9, 2019 | 11:27 AM
packman86's Avatar
packman86
Took it the the shop and was told I need a full transmission replacement. Either a used transmission or brand new one.
Either way, its going to be expensive and I'm just going to run 5th gear instead.
wikedgolf
Southern California
Dec 8, 2009 10:38 AM
greatgro
May 3, 2003 06:45 AM
Cooper-Ferret
Mar 12, 2003 03:39 PM
joshua
Mar 2, 2003 02:40 PM
