European MINIs European MINIs may look similar but there are some interesting differences. Learn more here!
Mini R60 country man 2012
Old May 20, 2019 | 08:00 AM
Nhyiraba's Avatar
Nhyiraba
Please any help,! I'm working on R60 country man which cranks but engine cannot stay on sometimes it will stay on for 2 minutes and go off again,
Old May 20, 2019 | 02:27 PM
Possible to need to scan for codes first: https://www.northamericanmotoring.co...d-q-and-a.html
Then once you have the codes, check the HPFP.
Old May 20, 2019 | 10:35 PM
Nhyiraba's Avatar
Nhyiraba
Thanks for your kind suggestion, please can you recommend a great affordable tool specific for MINI/BMW and also a link to buy the High Pressure Fuel Pump (HPFP).
Old May 21, 2019 | 05:17 AM
Tool is in that link^^
You have a 2012 MINI Countryman S?
Old May 21, 2019 | 09:46 AM
Nhyiraba's Avatar
Nhyiraba
please its 2014 Mini cooper country man N14 engine, the engine cranks good but can't idle for 1 minutes,
Scanned it with ISTA but no fault codes on power supply,misfires or even fuel supply.
Last week friday it was idling for about 2 minutes and went off checked the HPFP side and there was no fuel so i removed the fuel pump from the tank and saw there was no fuel i have fill the tank with SHELL V-POWER tried it and no good results.
Old May 21, 2019 | 10:21 AM
Can i have the last 7 digits of your VIN, i want to make sure you get the correct HPFP part #.
Old May 21, 2019 | 10:30 PM
Nhyiraba's Avatar
Nhyiraba
Thanks it's ( WS48409)
Old May 21, 2019 | 10:44 PM
Nhyiraba's Avatar
Nhyiraba
This the control unit tree of the car
Fault codes (1)
Fault codes (2)
Fault codes (3) Please kindly go through the fault codes and suggest what to do thanks, God bless you.
CRiSP
Jul 12, 2017 06:07 PM
borisf
Jun 6, 2017 08:58 AM
gfx
Jul 30, 2016 02:28 PM
Deutsch
37
Jul 22, 2012 04:01 PM
