R56 Radio need to be coded upon replacement and ??
Old May 19, 2019 | 07:27 AM
Lipofskyphoto's Avatar
Lipofskyphoto
Dead radio, display, chime. 2009 Base CD boost.
Removed radio (pretty easy). Radios available $60 - $100 at parts yards.
Do I need to code or wake up the "new" radio? If so, how?
I have an obd cable for my laptop and understand that there is software available to code.
Has anyone ever figured out what, exactly does cause the radio to fail?
Old May 19, 2019 | 12:27 PM
A383Wing's Avatar
A383Wing
radio should not have to be "coded".....at least on the Gen I cars.....I read somewhere here in the forum recently that someone else asked the same question and they did not have to code that radio either....I just can't remember what year the car was
Did you check all your fuses? Did you check for codes?
Bryan
Old May 19, 2019 | 12:49 PM
Lipofskyphoto
This is, of course a Gen 2 car.
All fuses good, including the one on the back of the unit. No codes.
Anyone know if an R56 needs to be coded?
Old May 19, 2019 | 01:54 PM
A383Wing's Avatar
A383Wing
The radios made until about 2003 did require that you enter a code after it had been disconnected from power. Newer radios do not require a code (they use a different security mechanism that detects when they are plugged into a MINI, and automatically unlocks).
found this after a search
Old May 19, 2019 | 03:41 PM
Lipofskyphoto
Thanks for doing that!
Great news. I can be up and running for $60 +_ and not a lot of work. I hope!
I/m assuming that the problem lies within the CD/Radio unit, not the display module.
Old May 20, 2019 | 08:05 PM
Lipofskyphoto
Installed $50 junk yard radio.
Works! But, this radio shows the USB option, but no Aux option.
My radio had no USB, but did have Aux.
Back to the junkyard to get the aux/usb connector and cable. That may fix it.
Also, now shows a phone option, but see no way in menu to configure.
Can anyone enlighten me?
sootyvrs
Jul 23, 2016 06:29 AM
Tata Steva
Sep 7, 2013 08:47 AM
JeffHarper
Electrical
Mar 29, 2013 06:07 AM
DCM
Tires, Wheels, & Brakes
18
Feb 28, 2006 12:58 PM
Panganiban
Jul 30, 2004 09:16 AM
