Helicopter noise in neutral with clutch engaged
Old May 3, 2019 | 09:18 AM
Louis Demers's Avatar
Louis Demers
2006 mini cooper S 41k miles, Weird helicopter noise on idle it instantly goes away when you press the clutch pedal down but when you release you can hear it sounds like a distant helicopter.
is this normal op? Or is it an input shaft bearing or something? Could it be low trans oil?
Old May 3, 2019 | 09:22 AM
JAB 67's Avatar
JAB 67
Best guess is that it is the sound of the OE dual mass flywheel.
usshelena725's Avatar
usshelena725
If it goes away when you depress the clutch pedal, it is often a bad transmission input shaft bearing.
Old May 3, 2019 | 10:00 AM
Altecfenix's Avatar
Altecfenix
Yeah, that's about what I'd say that sounds like. Cursed "non-serviceable" transmissions
Old May 3, 2019 | 11:02 AM
Dan_in_WA's Avatar
Dan_in_WA
This is the Getrag 6 speed, correct? From what I’ve read so far, you have the best trans of the bunch.
I’d look at the oil level in the trans, and replace it if you can. Save the old lubricant, it can be tested to see if there are metal particles and what they are. It’s like a blood test, and will tell you for sure if the trans is on it’s way out.
Just search the ‘net for a good lab, or your local parts store might be able to point you in the right direction.
The test would be cheap compared to the cost of R & R of the trans, if it doesn’t need it.
Mini Mania probably has a rebuild kit.
Good luck and let us know what you find.
Dan
ericscottf
May 6, 2013 09:03 AM
CHILI-TIME
Tires, Wheels, & Brakes
Dec 11, 2009 08:04 PM
cmyk
Jun 19, 2006 08:46 PM
atn57
Dec 16, 2004 02:03 AM
