FS:: 2011 Cooper S M6 R56S Chili Red - White Modded
Old Apr 30, 2019 | 08:33 AM
smokeysevin's Avatar
smokeysevin
Year: 2011
Model: Hardtop
Price: $6000
Mileage: 122696
Color: Chili Red and White
Location (Region): Texas
Selling my 2011 Mini Cooper S manual trans. Owned since new, purchased in August 2011 from Mini of The Woodlands.
WMWSV3C55BTY23590
122696 Miles
Lots of aftermarket parts, full maintenance records and replacement part list will be uploaded. The car was well taken care of, oil changes every 5k since new with Mobile 1 Euro 0w40 and OEM filters.
There is a small dent on rear passengers side quarter panel near tail light from 2012 I believe it is not on the title as it was not reported to insurance. Small (quarter sized) dent on tailgate. No other damage. Standard rock chips on hood from Houston roads.
Clutch and flywheel replaced, timing chain and guides replaced.
Comes with stock 16" rib spoke wheels and tires. New tires on Team Dynamics 17" wheels. New in box axles, not installed but come with the car, were purchased but not needed.
Asking 6000k OBO, want it to go to a good home. I loved this car but I needed something bigger.
PM for more details,
Sean
Old May 13, 2019 | 09:01 AM
smokeysevin
Currently installed modifications are:
Powerflex lower control arm bushings (installed august 2017)
https://www.waymotorworks.com/powerf...shing-kit.html
DDM Works Race Intake (installed March 2018)
http://www.ddmworks.com/DDMWorks-R56...r-S_p_155.html
Intercooler, chinese knockoff (installed August 2017)
Remote Oil Cooler Kit (installed November 2017)
Custom front mount behind grill[img]file:///C:/Users/SOsborne/AppData/Local/Packages/oice_16_974fa576_32c1d314_ae2/AC/Temp/msohtmlclip1/01/clip_image004.jpg[/img]
Innovate MTX-D Oil Pressure and Temp gauge (installed November 2017)
https://www.innovatemotorsports.com/.../MTXD.php#3852
Autometer Ultra-lite Mechanical boost gauge
Custom mounted behind gauge cluster
[img]file:///C:/Users/SOsborne/AppData/Local/Packages/oice_16_974fa576_32c1d314_ae2/AC/Temp/msohtmlclip1/01/clip_image006.jpg[/img]
NM Engineering dual port boost tap
http://www.nm-eng.com/254/0/0/1458/n...ensor-tap.html
4 X 215/45ZR 17 General G-Max RS Tires (installed August 2018)
Team dynamics pro race 1.2 lightweight wheels 17*75 et 45 (July 2014)
https://www.outmotoring.com/mini-coo...-pro-race.html
Stop Tech Brake Rotors (Installed May 2017)
Akebono Euro Ceramic Brake Pads (installed May 2017)
Cravenspeed Dipstick (installed May 2017)
https://www.cravenspeed.com/the-dips...r56-2006-2013/
John Cooper Works Carbon fiber shift ****
John Cooper Works Carbon fiber handbrake lever
Hella Black Magic Rally 500 driving lights with yellow laminx covers (wired to trigger on fog light switch)
http://www.myhellalights.com/index.p...s-black-magic/
[img]file:///C:/Users/SOsborne/AppData/Local/Packages/oice_16_974fa576_32c1d314_ae2/AC/Temp/msohtmlclip1/01/clip_image012.jpg[/img][img]file:///C:/Users/SOsborne/AppData/Local/Packages/oice_16_974fa576_32c1d314_ae2/AC/Temp/msohtmlclip1/01/clip_image014.jpg[/img]
HPS Silicone cooling and thermostat hoses (installed November 2017)
http://www.hps-siliconehoses.com/07-...-hose-kit.html
Forge Motorsports Silicone Intake Tube (installed December 2017)
https://www.ecstuning.com/b-forge-pa.../fminlr60~frg/
Forge Motorsports Diverter Valve (installed 2015)
https://www.forgemotorsport.com/Blow...duct--782.html
Hard Wired Radar Detector wiring installed (key on circuit)
The following Maintenance Items have been completed:
Oil Pressure Control Valve Solenoid wire update (installed January 2018)
NGK ILZKBR7A-8G Spark Plugs (installed April 2019)
Ignition coil (Cylinder 1 installed April 2019)
JMturbocoopers lightweight steel flywheel and stock clutch disc (installed august 2017)
http://jmtcperformance.com/dual-mass...-jcw-r-series/
[img]file:///C:/Users/SOsborne/AppData/Local/Packages/oice_16_974fa576_32c1d314_ae2/AC/Temp/msohtmlclip1/01/clip_image016.jpg[/img] [img]file:///C:/Users/SOsborne/AppData/Local/Packages/oice_16_974fa576_32c1d314_ae2/AC/Temp/msohtmlclip1/01/clip_image018.jpg[/img]
During the clutch install the following parts were also replaced at the same time as the clutch replacement
Pivot ball
Guide sleeve
Flywheel Bolt
Clutch fork
Transmission fluid (Redline MT90)
I also have the following parts that were not replaced but were purchased and will be included with the car.
Clutch master cylinder
Clutch slave cylinder
The entire cooling system has been replaced in the last two years
Water Pump and Thermostat
Crossover Pipe (under intake manifold)
Coolant reservoir and cap
Super Start 48PLT Battery (Replaced last year)
Timing chain guides and tensioner (installed February 2019)
https://www.ecstuning.com/b-assemble...1311439853kt2/
Intake Cam Vanos Solenoid (replaced February 2019)
The valve cover was replaced in 2016
High Pressure Fuel Pump (Replaced February 2017 Mini of Sugarland)
Vacuum Pump (Replaced November 2017)
I have the following parts which will go with the car but are not installed
Drivers side and passengers side axle (bought but didn’t need to replace)
Cabin Air filter
4 X Stock 16” Rib Spoke Wheels with old Pirelli P5 Tires
Stock Intercooler
Stock Alternator Belt Tensioner
Stock water pump drive wheel tensioner
Stock Diverter Valve
1 spare Hella Black Magic Rally 500 driving lamp
1 wix Oil filter
1 John Cooper Works Strut Tower Brace
1 Custom low-profile intake mount to use with John Cooper Works Strut tower brace
1 OEM Mini Chili Red Touch Up Paint Kit
1 stock cooling reservoir and cap
1 BSH oil catch can and fittings (not installed currently, was removed when new intake was installed due to clearance issues)
Make a reasonable offer, located in the Houston area.
Sean
aerodynamics
Feb 20, 2017 12:35 AM
Duck360198
May 14, 2009 11:30 PM
TiMINITim
MINIs and Minis for Sale (archive)
Feb 24, 2007 07:50 AM
Batman1usa
Oct 26, 2006 08:56 AM
fripp
18
Apr 7, 2003 09:51 AM
