I figured it out and.. it's not good
Old Apr 27, 2019 | 05:52 PM
Chey Horton's Avatar
Chey Horton
Well. I have a 2002 mini Cooper s and it was having trouble going into gear with the car on so I replaced the slave cylinder. But that didn't do anything. I set it up in my garage and started tearing away at it to get at the clutch. Finally got the transmission off and everything and I figured out why it was having trouble to go into gear I guess my pressure plate exploded and wouldn't let it go into gear or it broke when I dropped it off of the flywheel but I think it broke while the car was running before then. Here are some pictures.
Old Apr 28, 2019 | 06:27 AM
Tgriffithjr's Avatar
Tgriffithjr
Great opportunity for an upgrade! Always turn lemons into lemonade.
Old Apr 28, 2019 | 08:27 AM
Chey Horton
Sure is. I'm going with the valeo solid flywheel conversion kit.
Old Apr 28, 2019 | 03:03 PM
cooper48's Avatar
cooper48
Wow! I've never seen a pressure plate break in half like that before. There must have been some serious forces to cause that heavy a damage. I just installed a Valeo flywheel, disc, pressure plate on my R53 and am really liking it. You'll need to get used to the light clutch pedal feel though. It's very different.
Old Apr 28, 2019 | 04:05 PM
Chey Horton
Oh yeah? How much of a difference is it from stock? I've heard pretty much nothing but good things from the valeo kit
Old Apr 28, 2019 | 07:51 PM
Chey Horton
Quick question. Is the fork supposed to be able to slide out of the top bushing? Because as far as I can tell they look fine and normal
Old Apr 29, 2019 | 06:59 AM
cooper48's Avatar
cooper48
Yep, that fork is not a problem. The guide tube will hold it in place. When I first installed the Valeo the pressure required to push the clutch was so much less than my last clutch I thought that air had made it into the hydraulic line somehow even though the system was sealed the entire time. After a few queries on the Forum I realized that was just the way the clutch operated. It's not bad, it's just different and requires a while to get used to. It's not a "performance" clutch that would have stiffer springs in the pressure plate so for everyday driving it's perfect.
Old Apr 29, 2019 | 07:08 AM
Chey Horton
that's good. I'm gonna be driving street normally anyway so that's perfect
Old Apr 29, 2019 | 09:29 PM
ItsmeWayne's Avatar
ItsmeWayne
If the guide tube shows wear, replace it and make sure to lube it with high heat grease. You don't want it sloppy, or disengaging will become an issue later on.!
Old Apr 30, 2019 | 05:04 AM
Chey Horton
Update: valeo kit came in. Sadly. The boxing looked extremely beat up and when I opened it it was a mess and there where bolts everywhere. The only piece of the kit with plastic was the throw out bearing and they put it under everything. So my throw out was broken into many pieces. I'm sending it back and buying from somewhere else. Looks like it's back to waiting
Old Apr 30, 2019 | 06:09 AM
Tgriffithjr
Tell us who you bought from and what shipping carrier they used.
Old Apr 30, 2019 | 06:57 AM
Chey Horton
Amazon Amazon
and shipped with UPS. Anywhere better I can get it. And quickly?
Old May 3, 2019 | 08:20 AM
n1nja508's Avatar
n1nja508
does everything operate more or less the same (besides clutch feel) compared to the stock? Having a few issues and wanted to verify
Old May 3, 2019 | 08:25 AM
Chey Horton
yes. From what I've heard it operates the same beside the light pedal and I've heard its a little louder than stock since it's solid. But other than that. I don't know. I ordered my replacement from ecs tuning and hopefully it will be in Saturday or Monday.
n1nja508's Avatar
n1nja508
Does the Valeo clutch more or less function the same as the stock clutch? (Besides clutch pedal feel) Installed one and my MINI just feels sluggish but its still in the break in period. Engages and disengages but just doesn't feel like it would hand quick acceleration without possibly slipping. Any advice would be greatly appreciated!
Old May 3, 2019 | 09:46 AM
cooper48's Avatar
cooper48
I'm running approx. 195hp on my MC40 and my Valeo clutch is working perfectly, even under hard acceleration. There is no related noise or vibration due to it being a single-mass flywheel.
Old May 6, 2019 | 07:44 AM
Chey Horton
I should be getting the valeo clutch in today! Yay. I'll keep you guys updated.
mde123
Nov 25, 2009 12:25 PM
Jedi1
Feb 22, 2009 06:36 AM
Silkworm
Jan 15, 2008 05:08 PM
donato
Jan 6, 2008 09:05 PM
racingdynamcs
Nov 3, 2005 08:36 PM
