R60 Oring on the back of the water pump
Old Apr 22, 2019 | 06:56 AM
Red Robin's Avatar
Red Robin
Is this oring a common leak on the R60?
I replaced the water pump that was leaking 3 months ago now this oring is. Coincidence?
If you have had it leak, how hard was it to remove that pipe?
Old Apr 23, 2019 | 10:00 AM
The o-ring(near the pump) does not leak most of the time the end pipe can crack and get a hairline crack in it. At the clip part to the waterpump i have seen that leak. Most of the time the clip is missing of after a water pump replacement the back end of the theromstat was not seated all the way in the water pipe.
DIY here: https://www.northamericanmotoring.co...hermostat.html
and Here: https://www.northamericanmotoring.co...stic-pipe.html
Old Apr 24, 2019 | 07:57 AM
Red Robin's Avatar
Red Robin
When removing the thermostat to replace the water pipe would be ok to only replace the thermostat gasket and oring?
Old Apr 24, 2019 | 08:04 AM
Yep, you can do that since the thermostat housing is good. That way when you take it apart you will have new gaskets and not older gaskets that have been compressed.
Old Apr 28, 2019 | 12:44 PM
TX-Mini05's Avatar
TX-Mini05
That pipe is such a bad design, you think they could come up with something better. I will be doing the pipe and housing this weekend.
Old May 3, 2019 | 08:38 PM
Alpha Motoring's Avatar
Alpha Motoring
Yes you can replace just the o ring but I would replace all of it due to the parts cost vs the amount of work to do the job again, if and when the parts fail.
nlinesk8s
Jun 5, 2023 07:22 AM
89325iturbo1
Feb 17, 2019 04:06 PM
theimage
Feb 5, 2018 07:13 AM
BigGar
Apr 23, 2017 04:49 PM
Little Bean
R55 :: Clubman Talk (2008+)
Dec 26, 2012 03:23 AM
