FS:: Brembo JCW GP2 6-Piston BBK - Calipers/Rotors Big Brake Upgrade
Category: Brakes
Price: $1950
Location (Region): Midwestern
These custom/refurbed units are ready to bolt on. Same execution with logos buried under the clearcoat (2-part urethane base/clear). Custom, matte finished rear vanity plates. New ceramic pads/plates/hardware, and reworked front brackets (135i) for the ~3mm offset and ~2mm lug span adjustments required when used on a Mini. (Info on that here) New Centric high carbon dimpled rotors (visible side only). Accessory items (MC, lines, dust shields) are not included, as that stuff is easy to source, isn't required, and you may have a preference on the type/brand used. Keep in mind these front units are beefy, so you'll want to make sure you can fit them, either with spacers, or with new wheels altogether.
Here are some tools to help you out:
- Wheel template: http://bd8ba3c866c8cbc330ab-7b26c6f3...t_template.pdf
- Installation guide: http://bd8ba3c866c8cbc330ab-7b26c6f3...tallation1.pdf
PM or post with any legit questions about the work/package and I'll do my best to answer them. Most answers are already on the forum, here. Price is negotiable, and keep in mind I will price-match anyone else selling an identical package.
- C
