R50/53 Passenger seat levers not working
Old Mar 26, 2019 | 08:35 AM
r53-06m6's Avatar
r53-06m6
Hey,
The seat levers are not working. The passenger seat does not recline and cannot be moved forward/backwards. Are there any common causes? I don't want to replace the seat if I can avoid it since it looks fine cosmetically.
Thanks.
Old Mar 26, 2019 | 11:07 AM
Racingguy04's Avatar
Racingguy04
I've had this happen a couple of times, This is what has helped me in the past. https://new.minimania.com/MINI_Seat_..._problem_02_06
it takes more force than it seems like it should, but this has always fixed it for me.
Old Mar 26, 2019 | 12:12 PM
Mineeee's Avatar
Mineeee
Ive had two issues with mine,. one was the recline fault where the seat back angle didnt want to change, which was fixed with the brute force method above^^^ which worked for me after a slightly terrfying BANG. The other was the tilt and slide access to the rear seats was not working, which was fixed by replacing the release cable as detailed here.
I also had the forward/back slide mechanism jam, but that turned out to be a lipstick that had been dropped into the channel stopping the seat moving.
Good luck.
Old Mar 26, 2019 | 12:36 PM
Alpha Motoring's Avatar
Alpha Motoring
Pull the lever up and slam your body weight into it, it'll free it up.
Old Mar 27, 2019 | 02:35 PM
+1 Have seen the slam method work, just like theFonziee method on the window motors.
Old Mar 28, 2019 | 11:32 AM
r53-06m6's Avatar
r53-06m6
I am just dumb I guess. I didn't understand how all of the levers work. Fortunately they do work. I will try this stuff when things eventually end up like this.
Thanks.
Old Mar 28, 2019 | 12:59 PM
Mineeee's Avatar
Mineeee
Thanks.
LOL, those are the best kind of fixes, dont forget to enjoy a beer for fixing it
In any case its likely only a matter of time before you will need this information anyway!
MattyKHZ
Jun 1, 2012 12:14 PM
cshumer
Feb 7, 2008 05:47 AM
willymcd
Aug 29, 2005 09:56 AM
