Rear main seal leak.
Old Mar 23, 2019 | 06:47 PM
89325iturbo1's Avatar
89325iturbo1
So I just got finished doing some repairs, and clutch on my mini. When doing the clutch I replaced the rear main seal.
ive only driven it a couple times since the repairs, and I've gotten a 4-5" puddle on the ground after driving. Intially I thought maybe the power steering hoses were leaking. But once I got under there and took a better look didn't seem to be the case.
I replaced the hoses anyway, since they were old and leaking slightly some.
so it looks like it's leaking from the weep hole were the trans and oil pan meet. Even though right at the weep hole doesn't look to oily. Going towards the rear it gets more oily (probably just blowing backwards at speed)
long story short is it most likely the rear main seal?
Got damaged when installing? Don't remember feeling like I damaged it. But it took some work to get it fitted. Just stinks i don't feel like removing it again, since I just had it removed.
Old Mar 24, 2019 | 05:55 AM
Tgriffithjr's Avatar
Tgriffithjr
Jack it up, clean everything well under there the start it and look for oil dripping. Make sure it’s on solid jack stands and the e brake is holding. If it’s leaking that much from the rear main it shouldn’t take long to see the drip. Run it up to about 2000 rpm to get good oil pressure which will help speed the drip up.
Old Mar 24, 2019 | 06:06 AM
89325iturbo1
Yeah I did that last night. Wiped it off let it run for 10-15 minutes giving it some gas in between.
Dropped it back down to let it sit level over night, gonna check it this morning.
Old Mar 24, 2019 | 06:53 AM
Tgriffithjr
Yeah but how are you going to know where the oil is dripping from if you don’t visualize it? That’s why I said get under it while it’s running. You want to rule out or rule in the rear main. If it’s not dripping from the weep hole, which you said you couldn’t tell previously, then you can start looking somewhere else for the leak.
Old Mar 24, 2019 | 11:09 AM
89325iturbo1
I did look under when It was running but didn't see anything in that amount of time . Then I thought maybe the angle of the car would prevent it from coming out of the weep hole if it was leaking from there.
plus with everything clean, if there was a clear wet spot on the other side of the oil pan obviously it wouldn't be coming from the rear main seal.
This morning when I checked there wasn't any puddle on the ground but a little wetness around the weep hole were the pan and trans meet.
I'm guessing maybe not as much oil since it wasnt driven and didn't the romping of going through the gears at higher revs.
Old Jan 5, 2020 | 06:45 AM
JAB 67's Avatar
JAB 67
The previous poster mentions a "weep hole." Where exactly is that, and if the rear main seal is leaking is that where it will be apparent?
Old Jan 7, 2020 | 10:56 AM
ssoliman's Avatar
ssoliman
wondering myself.
think it’d be the bottom, back, left side of the motor. Where oil pan meets trans.
see pic attached. Right bottom of the pic you can just get a glimpse of it. Sorry horrible pic
JAB 67
Jan 4, 2020 04:50 PM
alconk
Aug 2, 2019 02:48 PM
jjcsnlynn
Apr 29, 2018 11:31 AM
nivek111070
Jan 14, 2016 12:33 PM
RadioActiveMan
May 26, 2014 09:46 AM
