R50/53 R53 coding stage 1 cooling fan
The way the low speed fan works is simply a resistor in the system, it's not an actual 2 stage fan, I don't remember the temp ranges, but basically at lower (hot) temps and when the A/C is on, the power is sent through the resistor, causing a restriction in current and therefore a slower fan speed, above that temp point, the fan gets full current therefore full speed.
If you reinstall the resistor, just make sure that the wiring is still all there, if the previous owner got rid of it also, the resistor wiring is, and needs to be, a heavier gauge (I think 10ga) than the full speed wiring due to the extra heat generated by the resistor.
You can buy a replacement low speed fan resistors on ebay, amazon, other parts stores. If you're not comfortable with soldering a new resistor or if the previous owner really butchered things, you may have to repalce the whole fan unit.
majestic
Mar 31, 2015 11:27 AM
Dan1967
Sep 19, 2010 04:36 PM
guitfiddler
Oct 10, 2007 12:04 PM
ilscoobydooll
Jun 4, 2007 02:47 PM
